Video accessory
biznisman2u
Copper - Posts: 59
Posted: April 05, 2004 at 11:53 PM / IP Logged
I am getting a lcd video/ monitor.... i wont to use my home dvd player. and i was wondering what else i need ... the shop said I need a $50 Converter for the two different power supply and I also need a $50 FM modulator. i'm guessing this will send the sound to the speakers. .... is this the best way to do it. and will it sound good coming from a pair of good speakers with an amp on to them.... what other suggestions may any one add if not...????
Biznisman2u
Moderator - Posts: 12,488
Posted: April 06, 2004 at 1:16 AM / IP Logged
This is probably the most cost effective way of doing this integration yes. You could probably shop around a bit more for a better price, but if they are going to install it as well, then see what you can do as far as installation price from these guys.
eeh1025
Copper - Posts: 113
Posted: April 08, 2004 at 10:22 PM / IP Logged
hey there you could do it that way but that would be a big paint and take alot of juice fot the powerinverter, heres what i would do, 1st question do you already have a head unit? if yes you can buy a dvd unit from ebay that will not use the inverter, it hooks right up to 12v and you get a 1ft rca cable and hook that output from the dvd unit to the aux input of you head unit. If you have no head unit you can use the dvd unit as one. here are some links.
http:///.com/dll?ViewItem&category=32825&item=3088860850&rd=1
http:///.com/dll?ViewItem&category=32825&item=3088897440&rd=1
http:///.com/dll?ViewItem&category=32825&item=3090432281&rd=1
http:///.com/dll?ViewItem&category=32825&item=3090542200&rd=1
Ravendarat
Platinum - Posts: 2,806
Posted: April 09, 2004 at 12:50 AM / IP Logged
If you try using a home DVD player in a car, its probally gonna skip like a 7 year old girl. Just an observaton
Nocturnal
Copper - Posts: 85
Posted: April 09, 2004 at 1:09 AM / IP Logged
Probably?  It will skip.  Unless you drive on perfectly smooth pavement.   Where does that exist?
Friday, January 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
