Power window switch wiring
undertheradar
Posted: April 06, 2004 at 11:32 AM / IP Logged
I have installed a SPAL power window kit in my 96 DX. I bought some aftermarket switches to mount in the center console. The switches are 12v DPDT momentary rocker switches like these...
Power window switch wiring -- posted image.
Heres what the back of the switch looks like
Ande heres what the info sheet that came with the switches says:
They have 5 wires, but my kit only has 4 connections to be made...power, ground and the two contacts to the motor. Any idea how these things should connect. I messed with it a little bit, and I can get the switch to roll the window up one way or the other, but not both. Anybody wanna help me out? I'll get a pic of the actual switch and wires in just a sec. I guess I can call the place I got it and check, but I wanted to get these thing hooked up tonight.
Thanks guys!
draasch
Gold - Posts: 2,172
Posted: April 06, 2004 at 1:09 PM / IP Logged
call 1-800-345-0327 and ask for tech support they should be able to walk you through the wiring...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
