Double pulse unlock
dizturbd2
Posted: April 08, 2004 at 9:41 PM / IP Logged
I am trying to figure out a way to make a single pulse unlock into a double pulse unlock using relays and maybe diodes, but no capacitors.
CalG
Member - Posts: 9
Posted: April 14, 2004 at 12:46 PM / IP Logged
There is a reply to this on the security forum from about 2-3 weeks ago.
A capacitor in series with the NC common and the relay coil  does the trick.
I get the timing I want with a 2400 mfd cap.
http://www.designtech-intl.com/Content/techsupport/documents/section04/note231.pdf
Check this link.
Regards
CalG
Teamrf
Gold - Posts: 1,031
Posted: April 14, 2004 at 2:36 PM / IP Logged
On the DEI alarms they have a program feature that you can change this too.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
CalG
Member - Posts: 9
Posted: April 14, 2004 at 3:39 PM / IP Logged
I bet this can be done with two relays as well.
The second relay wired to system voltage makes use of the NO function and injects a + signal while the - signal is in process.
By the time the things repeat, the activation signal is over.
I would need to play around at the bench.
Think about it.
CalG
CalG
Member - Posts: 9
Posted: April 14, 2004 at 3:52 PM / IP Logged
First pass says that if the second relay has it's coil energized thru a  suitable resister, it can be made to drop out as soon as the NC contact makes connection.
Too bad I don't know how to post a relay diagram here.
For those who would just advise to buy the accessory double pulse device,  Sometimes it is more fun to know than to have.
Regards
CalG
CalG
Member - Posts: 9
Posted: April 15, 2004 at 4:20 PM / IP Logged
Tried to get this to work last night, but could only manage a buzz.
Capacitance can be a beautiful thing.
CalG
the12volt
Administrator - Posts: 3,957
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
