two amps
tommer2
Posted: April 08, 2004 at 10:05 PM / IP Logged
Aloha Guys,
I just bought a Bazooka 8" for my regular cab S10. I have a Coustic 241SE Amp. Will this combo work well? Will it have enough power? To wire this up, will I bridge this?If not, how should I?
Another question please. I want to add another amp for my Alpine 2 way speakers in my doors. Can I daisey chain another amp from my Coustic Amp? I know I would need to run a seperate hot and ground wire. If so, what amp would you recomend for this. My head unit only has one set of RCA outs so that's why I need to daisey chain them. Please, all you experts let me know what you think!!!!!!!! Thanks in advance.
Thom
Ketel22
Silver - Posts: 976
Posted: April 09, 2004 at 1:11 AM / IP Logged
first off which series subs did you buy?
for your second question yes you can but it will definately destroy your amps and maybe your speakers. i would advise against using the "daisy chain" method and just buy a second amp that has more power.
Quad L Handyman services
DYohn
Platinum - Posts: 10,741
Posted: April 09, 2004 at 8:29 AM / IP Logged
... unless by Daisy Chain you simply mean running the RCA pre-amp signal to both amps.  This is OK.
Ketel22
Silver - Posts: 976
Posted: April 10, 2004 at 2:45 AM / IP Logged
run your amp bridged to the sub, from what i can find the sub tube is 150wrms and the amp will put out a supposed 240wrms. i dont know how accurate the coustic amp ratings are but you may want to leave the gains on the lower side.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
