02 civic si wire codes
sigouge02
Posted: April 11, 2004 at 12:59 PM / IP Logged
I just recently purchased my car and now am wanting to add an ungo alarm and do not have the current wire charts for 2002. Any help with this would be great.
rudbwoy69camaro
Silver - Posts: 350
Posted: April 11, 2004 at 4:42 PM / IP Logged
2002 Honda Civic
ItemWire ColorPolarityWire Location
12Vwhite+ignition harness
STARTERBLACK/ white+ignition harness
IGNITIONBLACK / YELLOW+ignition harness
ACCESSORYBLACK/ red+ignition harness
SECOND ACCESSORYnone
TACHOMETERbluetest connector *4
POWER LOCKWHITE/ blue-gray plug above drivers kick
POWER UNLOCKWHITE/ green-gray plug above drivers kick
PARKING LIGHTS +RED / blackback of the fusebox
PARKING LIGHTS -bluefactory alarm plug *1
DOOR TRIGGER*2-factory alarm plug *1
HEADLIGHTSblue/red-headlight switch
WIPERSblue (L), blu/yel(H)-steering column
LF WINDOW UP/DNRED / blk - RED / yelAdrivers window switch
RF WINDOW UP/DNblu/red - blu/whtAdrivers kick panel
LR WINDOW UP/DNbrn/wht - brownAdrivers kick panel
RR WINDOW UP/DNblu/org - brn/yelAdrivers kick panel
TRUNK/HATCH PINred-factory alarm plug *1
HOOD PINnone
TRUNK/HATCH RELEASEnone
FACTORY ALARM ARMnone
FACTORY ALARM DISARMnone
HORN TRIGGERorange-steering column
BRAKE WIREWHITE/ black+brake pedal switch
LOCK MOTORyellow/blackback of the fusebox *3
UNLOCK MOTORYELLOW /GREENback of the fusebox *3
DISARM DEFEATyellowback of the fusebox *3
DISARM NO UNLOCKnone
DOME SUPERVISIONcomes on with unlock
SPEED SENSEWHITE/ greenPCM *5
SUN ROOF OPEN/CLOSEnone
SUN ROOF LIMITnone
LF SPEAKERgrn/blk - lt greenradio
RF SPEAKERgrn/yel - gry/redradio
LR SPEAKERblu/wht - blu/blkradio
RR SPEAKERpink - blu/yelradio
RADIO 12VWHITE/ red+radio
RADIO GROUNDblack-radio
RADIO SWITCHyellow/red+radio
RADIO ILLUMINATERED / black+radio
POWER ANTENNA
Notes:NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555I or 555U. *1 The factory alarm plug is a green plug above the drivers kick panel. *2 The drivers door trigger is green, front passenger door trigger is lt. GREEN/ red, and the rear door trigger is GREEN / WHITE. *3 In the top left plug. *4 It is a 2 pin plug to the passenger side of the battery. *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
turbocivic42
Posted: April 29, 2004 at 10:17 AM / IP Logged
Is this the same wiring for the 04 si? Any info would be great.
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
