Ohms an amp sees when bridged
kfr01
Gold - Posts: 2,121
Posted: April 12, 2004 at 8:12 AM / IP Logged
Awesome .. These last two posts are what I was looking for.  I will completely rule out briding an amp to my components and just look for a good quality 2 channel amp to run at 4 ohms.  Thank you haemphyst and stevdart!
Karl
haemphyst
Platinum - Posts: 5,054
Posted: April 13, 2004 at 4:42 AM / IP Logged
one thing i did forget to add, however... buy a nice 4 channel amp (one with a VERY flexible crossover included within, both high pass and low pass), or a small GOOD QUALITY two-way electronic crossover (ideally, with a 24 or 48dB slope - maintains absolute phase, a good thing), one that will allow you to crossover exactly where the passives included with your components do. this is the ultimate in decadence, run your tweeters off two channels, and the mid-bass from the other two... and you WILL get better sound without all of those lossy passive components in the signal path... if you had decided on 150wX2, then look for something around 50-75wX4... this might even cost you less than the big 2 channel... the eclipse ea3422, while not their premium line, but a grat bargain amplifier, will get you half way there... an additional benefit to this setup option? is your sound too bright? turn JUST the tweeters down... without using the noisy tone controls in your HU. the bi-wiring/bi-amping solution is FAR more flexible than a two channel setup. Ohms an amp sees when bridged - Page 2 - Last Post -- posted image.
2001 Honda Civic LX
Eclipse 8051 E8 deck
Eclipse 3122 driving Infinity emit Kappa tweeters 80w X 2
Eclipse 32440 driving Eclipse 89940 Point source 6X9's 120w X 4, bi-wired, bi-amped
Eclipse 34230 driving Morel MW-162 6" midbass in doors 370w X 2
Eclipse DA7122 driving Eclipse SW9122 12" Titanium sub 1350w X 2
RedTop Optima 12v under the hood
2 RedTop Optima 6v in trunk, one each side wired in series
2 Rockford Fosgate 1 Farad caps on custom hand built power bars
Alterstart 165 Amp alternator with Datel 150A Current Shunt and blue LED meter for monitoring current output
kfr01
Gold - Posts: 2,121
Posted: April 13, 2004 at 8:24 PM / IP Logged
haemphyst - thanks for the suggestion.  Now that you mention it, the Musicomp crossovers that come with the mb quart pce's allow bi-amping right on the crossover.  I think I'm going to pick up a 4-channel amp and go this route.  I like the idea of the tweater and woofer getting a separate dose of power.  Thanks again for the suggestion!
kfr
Thursday, May 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
