Ford Windstar door lock motor
tinchote
Member - Posts: 24
Posted: April 13, 2004 at 8:48 AM / IP Logged
I have successfully installed my alarm/remote-starter/keyless-entry in my 98 Windstar.
Now the problem is that the driver's door lock motor is not working well. When you press the lock/unlock button (or when I act it with the remote) it sometimes open, it never closes, and usually it does nothing, it starts to move but fails to change position.
Is this likely a mechanical problem with the rods (maybe requiring lubrication) or is it a motor problem ? Any help ?
godsegoizhuge
Copper - Posts: 214
Posted: April 13, 2004 at 9:07 AM / IP Logged
how well did it work before you installed everything?
tinchote
Member - Posts: 24
Posted: April 13, 2004 at 11:15 AM / IP Logged
It has nothing to do with the alarm.
Before installing it did the same. It opens perfectly with the key. But when using both lock/unlock buttons (left and right door) the driver's lock moves but doesn't change state.
I tried lubricating the motor and the rods in general, but not being able to look inside the door I might be missing something. The other chance is that there is something wrong with the motor.
italnpimp59
Silver - Posts: 427
Posted: April 13, 2004 at 1:14 PM / IP Logged
yeah the motor is bad, sounds like it anyway.  install an actuator in that door
tinchote
Member - Posts: 24
Posted: April 13, 2004 at 7:22 PM / IP Logged
I guess I'll try that. Problem is, can I install an actuator without taking the motor away ? Access to those rods is less than perfect, so I would like to mess with them as little as possible.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
