Door Locks and windows
vcysion
Member - Posts: 7
Posted: August 24, 2002 at 5:26 PM / IP Logged
Ok I am getting closer to getting this thing working.  I have a 99 dodge stratus.  I am looking for my lock and unlock wire for my doors.  Can't find them anywhere.  I even tried probing the wires that go straight to the harness behind the door panel but all i get is one that is nothing, one is 12v, another is nothing, and the last one (white w/ green) gives me 6V on lock and 2.5 on unlock.  I gotta be doing something wrong.  Please someone help.  Also my windows are supposed to go up when the alarm is activated.  I can't find that wire either.  the wire coming from the alarm that goes to the window wire is a + one.  http://www.q3wholesale.com/kg880diagram.html
Platinum - Posts: 12,488
Posted: August 25, 2002 at 12:40 AM / IP Logged
|       POWER LOCK|WHITE/ green         |+  |rear of fuse/relay box      |
|     POWER UNLOCK|same wire           |*3 |on drivers underdash        |
Use positive (+) trigger thru a 620 ohm resistor to lock, and a positive (+) trigger thru a 2.7K ohm resistor to unlock. Must use relays.
vcysion
Member - Posts: 7
Posted: August 25, 2002 at 11:54 AM / IP Logged
i am a newbie at this. is there anyway you can probably draw this out for me.
thanks
Posted: August 25, 2002 at 9:59 PM / IP Logged
http://www.bulldogsecurity.com/wires/images/chrysler1wirecars.htm
