Suggestions
Pjr_
Posted: April 14, 2004 at 8:29 PM / IP Logged
I need some suggestions on how to make this install look more stock in the dash. I am currently trying to use bondo and modify the old bezel around it but i am having very little luck.
Suggestions -- posted image.
dangerranger96
Copper - Posts: 163
Posted: April 14, 2004 at 8:59 PM / IP Logged
your local custom audio installer might be able to give you some ideas or tips
defective
Silver - Posts: 642
Posted: April 14, 2004 at 9:00 PM / IP Logged
i had this problem once... too much screen, not enough dash... :)
what i did was use a program to flip the screen sideways in tablet mode, then mounted the monitor sideways to fit in the constraints,  this way you can have you music video at the bottom of the screen and your playlist and eq at the top.... hope this helps
sam1
Copper - Posts: 151
Posted: April 15, 2004 at 9:55 AM / IP Logged
thats going to be tough to make it look stock.  thats a pretty big screen for that console.  might work better to make it flip down from an overhead console.  or maybe relocate your vents and scoot the screen up a couple inches where the console is a little bit wider.  dont know, just throwin ideas at ya.
kickerstang
Copper - Posts: 180
Posted: April 15, 2004 at 1:50 PM / IP Logged
what size screen is that??? damn!!  i'd say remove the vent's slide it up about 2 or 3" and mold it in to the dash. and you can put your deck in the bottom pocket
what!?!?! you want some??
Thack79
Silver - Posts: 526
Posted: April 15, 2004 at 1:57 PM / IP Logged
Id leave it positioned where it is. could be a bad glare at some points during the day if its any higher
Pjr_
Posted: April 16, 2004 at 8:51 PM / IP Logged
 It is a 10.4 inch touch screen monitor for the computer I have installed the motherboard and hd are sitting behind the screen, so I really want to leave it where it is. If I go any higher the sun will affect it.  A local shop quoted me 500 to fiberglass it in there i think that is way too much id rather try myself to glass it in.
nyguy4u
Copper - Posts: 148
Posted: April 16, 2004 at 10:28 PM / IP Logged
In my opinion, that screen is waaaaaaaay too big for that dash. Overkill.
xtreamcc
Silver - Posts: 467
Posted: April 17, 2004 at 2:35 AM / IP Logged
I'm sorry, I just dont understand the need for a computer built into your car... I could maybe see an adaptor built in so you could run it off your car, but I will never understand the need to put a computer and 50 LCD screens in the car. I'd personally just pull it out all together, get a high quality CD/MP3 player, drop some 15's in the back and go get the cops called on me. But thats just me Suggestions -- posted image.
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
Pjr_
Posted: April 17, 2004 at 6:26 AM / IP Logged
Some of the reasons I wanted the computer in my car are for GPS, OBD-II diagnostics, mp3s, and playing dvds.
