python lock actuators
davidwp13
Member - Posts: 28
Posted: April 18, 2004 at 1:02 PM / IP Logged
 Hi this is my first although I was warned against installing it myself, I feel comfortable that I can do it WITH a little help. I have a Python 660XP and the Python 524F actuators the module has 2 wires 1 for +lock/-unlock and the other is -lock and +unlock, 1 blue 1 green. I have yet to figure out which relay diagram I need to use. I found some here but can not access Python directfax for detailed diagrams on my system as I have no Dealer acct.
 ANY HELP????
David
auex
Platinum - Posts: 5,041
Posted: April 18, 2004 at 7:20 PM / IP Logged
The wires coming off of the actuator are the motor wires. You need to wire two relays like this,
python lock actuators -- posted image.
If your alarm has built in lock relays or are using a 451M then you would hook the purple wire to constant +12V, the brown and white to ground, and then the blue and green to the approriate wires. The blue and green wires coming from the alarm don't neccesarily have to go the actuators blue and green wires, this depends on how you mounted the actuators. If you hook it up one way and it is unlocking when you hit lock and locking when you hit unlock then flip the blue and green around.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
