1995 Intrepid Wiring
darkeagle
Posted: April 19, 2004 at 9:58 PM / IP Logged
I'm in the process of installing a Commando Prostart 3300 unit on my 95 Dodge Intrepid. Where can I find a complete wiring diagram for my car even for the more difficult things such as the door trigger switch?
Also, does the tach wire HAVE to be installed? Or can it be tach-less start?
draasch
Gold - Posts: 2,172
Posted: April 19, 2004 at 10:01 PM / IP Logged
Make:   Dodge
Model: Intrepid
Year:    1993-95
Alarm
Constant 12 volts RED & PINK/BLACK IGNITION SWITCH HARNESS
Ignition 12 volts DARK BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW (-) PIN SWITCH OR 12 PIN CON-DRV KICK
Trunk Pin Switch TAN/BLACK (-) DRIVER KICK PANEL - 12 PIN CONNECTOR
Parking Lamp BLACK / YELLOW @ LT SW. (+) OR BLK CONN-LEFT OF STEERING COLM
Power Lock ORANGE / WHITE IN LT.BLU 12-PIN CONNECTOR #202
Power Unlock PINK/VIOLET ON THE BACK OF FUSE BOX
#202- See Positive Pulse Door Lock Diagram.
Remote Start
Tach Signal GRAY, RED / YELLOW, BLUE / YELLOW @ COIL PACK ON ENGINE *
Ignition #2 RED / WHITE IGNITION SWITCH HARNESS (AIRBAG) #235
Ignition #3 BLACK/ ORANGE IGNITION SWITCH HARNESS (HEAT/AC)
Accessory BLACK/ WHITE IGNITION SWITCH HARNESS (WIPER/RADIO)
Neutral Safety BLACK/ GREEN GEAR SELECT SWITCH
Brake Light WHITE/ TAN (+) AT SWITCH
Reverse Light VIO/BLK OR BLK/LT GRN (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost
* Each Wire Listed Above Is A 2 Cylinder Signal. Wire Colors In Late Production Models Are RED, WHITE & BLACK At Coil Pack. #235- See Powering Extra Ignitions Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
darkeagle
Posted: April 20, 2004 at 7:54 AM / IP Logged
For the door trigger, a wiring diagram tells me this:
Door Triggertan and tan/red
Then is says this on the bottom:
Tan gets drivers door, tan/red gets pass. doors. Tap both wires and diode isolate.
What does that mean? The 'tap both wires and diode isolate.'?
godsegoizhuge
Copper - Posts: 214
Posted: April 20, 2004 at 8:35 AM / IP Logged
You'd wanna goto radio shack and buy 2 1 amp diode's. Then you take the diode's and put the side with the white band on it on the tan and the other diode on the tan/red. Then you take the other ends of the two and tie them together and hook it in with whatever color your door trigger wire is.
draasch
Gold - Posts: 2,172
Posted: April 20, 2004 at 8:38 AM / IP Logged
check for this wire:
Good Luck
David
Ace Security
813-376-9778
Tampa
darkeagle
Posted: April 22, 2004 at 9:01 PM / IP Logged
Where is the best place to put the shock sensor and the alarm, and how should I secure them?
Also, what type of wiring do the door locks use? 5-Wire Reverse Polarity, 3-Wire Positive, or 3-wire Negative?
Thanks so much.
