DEI-554R Valet alarm???
carguy411
Silver - Posts: 683
Posted: April 22, 2004 at 8:39 PM / IP Logged
anyone use the new 554R remote start alarm system from DEI. it looks pretty good but it seems like theres alot of extra wire hook ups than a normal R/s and alarm.. butlet me know what you think of the alarm and functions of it
thanks
BTW its going in a ,04 tahoe z71
thanks
draco1462
Member - Posts: 8
Posted: April 23, 2004 at 8:13 AM / IP Logged
I bought one last month and installed it myself carefully over 3 days leaving off the window control, door locks and starter cut-out for now as hooking up everyting else was a major test of my diagnostics since I had no wiring diagram of my car(94 merc) with the obd-1 system of on-board computers.
the alarm itself is pretty sophisticated as to its capabilities and configuration to the vehicle, it will even remote start a diesel waiting for the "wait to start" light to go out!, the range of the transmiter/receiver is a little shaky depending on local rf interference though or whats between you and the car. another weak spot is the wire gauge of the start/accessory relay system it was smaller then my existing wiring so I had to re-wire it to handle the load to keep it from becoming a possible meltdown and disabling the car completly(some circuits are spliced into existing wires not just paralelling them) finally let THEM install it as the factory will give you NO help unless your an authorised dealer
draco1462
Member - Posts: 8
Posted: April 23, 2004 at 8:18 AM / IP Logged
keep looking around for something not dei
kgerry
Platinum - Posts: 3,455
Posted: April 23, 2004 at 9:14 AM / IP Logged
it's a good little unit, only weak point i found was the range.... so i upgraded myself to the Clifford 3.5 which is very similar but actually in many ways superior to the 554R...longer range and security paging done in real time
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
