Wiring Diagram Please
Welcome Guest :)
93Prelude
Member -
Posted: August 26, 2002 at 5:50 PM / IP Logged
Hey all, I need a wiring diagram for a 1993 honda prelude VTEC.
Thanks in advance, Nick
hot_shot_guy123
Copper -
Posted: August 26, 2002 at 5:55 PM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | DTI Color | Vehicle Color | Location |
Start: | | Yellow | BLACK/ WHITE | IGNITION SWITCH HARNESS |
Ignition #1: | | Blue | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Ignition #2: | | Green | YELLOW | IGNITION SWITCH HARNESS (HEAT-A/C) |
Ignition #3: | | Wht/Blk | N/A | |
Accessory: | | White | WHITE/ BLACK | IGNITION SWITCH HARNESS |
Brake Light: | | Orange | GREEN / WHITE (+) | SWITCH ON TOP OF BRAKE PEDAL SUPPORT |
Tach Signal: | | Green | BLUE | AT DISTRIBUTOR OR TEST CONNECTOR * |
Parking Lights: | | Yellow | RED / BLACK | (+) HEADLIGHT SWITCH OR FUSE BOX |
Headlights: | | Yellow | BLUE/RED (LO) | RED / BLUE (HI) HEADLIGHT SWITCH (-) |
OEM Alarm Disarm: | | Brn/Wht | N/A | |
OEM Alarm Arm: | | n/a | N/A | |
Diesel Glow Plug: | | RED / Black | | |
Clutch Bypass Wire: | | n/a | | |
Notes: | | * Tach Test Connector Located On Passenger Strut Tower. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | Red | WHITE | IGNITION SWITCH HARNESS |
Starter Kill: | | Vlt or Wht | BLACK/ WHITE | IGNITION SWITCH HARNESS |
Ignition +12 Volts: | | Orange | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | Brown | BLACK/ WHITE (-) | DRIVER KICK PANEL OR PASS."B" PILLAR |
OEM Horn: | | Blue | (92) BLUE/RED (-)/(93) | GRAY OR BLUE/BLACK-STEERING COL.HARN. |
Power Lock: | | Wht/Red | BLACK/ WHITE | DRIVER'S KICK PANEL ** |
Power Unlock: | | Yel/Red | BLACK/ RED | DRIVER'S KICK PANEL ** |
Trunk Release: | | Grn/Wht | N/A | |
Alarm Input Wire: | | R/W or Gy/Bk | BLACK/ WHITE (-) | DRIVER KICK PANEL OR PASS."B" PILLAR |
Notes: | | ** See Note #201 - Negative Pulse Door Lock Diagram. |
"Light travels faster then sound, that's why some people seem bright until you hear them speak."
hot_shot_guy123
93Prelude
Member -
Posted: August 27, 2002 at 5:21 PM / IP Logged
Phatmex
Member -
Posted: December 08, 2002 at 2:27 AM / IP Logged
Is this the same diagram as the 94?
Moderator -
Posted: December 08, 2002 at 4:49 PM / IP Logged
1994 Honda Prelude:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white - wht/yel *1 |+ |steering column || STARTER|BLACK/ white *1 |+ |steering column || IGNITION|blk/yel - grn/blk *1|+ |steering column || ACCESSORY|yellow |+ |steering column || POWER LOCK|BLACK/ white *1 |- |pass. kick 10 pin plug *2 || POWER UNLOCK|BLACK/ red *1 |- |pass. kick 10 pin plug *2 || PARKING LIGHTS +|RED / black | |harness at fusebox || HEADLIGHTS|blue/red |- |steering column || DOOR TRIGGER|BLACK/ white *1 |- |inst. cluster plug *3 || TRUNK/HATCH PIN|GREEN/ black *1 |- |inst. cluster plug *3 || FCTRY ALARM ARM| | | ||FCTRY ALRM DISARM| | | || TACHOMETER|blue | |r.shock at test plug || BRAKE WIRE|GREEN / WHITE |+ |brake sw. or fuse box || HORN TRIGGER|blu/red - blu/blk *1|- |steering column || WIPERS|blue/white |- |left of column || LF WINDOW UP/DN|RED / yel - RED / blu |A |in drivers door || RF WINDOW UP/DN|blu/grn - blu/yel |A |in drivers door or dkp || SUN RF OPN/CLOSE|grn/yel - grn/red | |*4 |Notes:
*1 Also located at the factory security plug located to the left of the steering column. the plug is gray in color. There is a black wire in the factory security plug that is a ground. *2 Peel back foam on kick panel to locate harness *3 Located in gray 14 pin plug above hood release handle in far left corner of underdash. *4 Both are 16 awg in a harness exiting from midway between the top and bottom of the fusebox on the firewall side. Also locate in rocker panel in harness to rear.Jeff
Phatmex
Member -
Posted: December 08, 2002 at 9:08 PM / IP Logged
Moderator -
Posted: December 09, 2002 at 5:19 AM / IP Logged
No problemo
Wednesday, May 8, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
