DVD Player/Monitor
Jlyons78
Posted: May 01, 2004 at 3:51 PM / IP Logged
Hey. I just got a In dash Dvd/cd player(Pyle PLDVD168 In-Dash Mobile DVD/CD Player w/MP3 Playback), along with a in dash motorized monitor (Pyle PLVIN70 7" In-Dash Monitor with LCD Clock Display )  for my 2001 ford f-150.
Now my questions are, in order to install both, will i need an amp to power one of them? and if so  which one should i power through the factory power wires and which one through the amp and how would i go about connecting it to the amp?  and finally what kind of amp does it need to be?
Moderator - Posts: 12,488
Posted: May 02, 2004 at 9:25 AM / IP Logged
Neither needs an amplifier. The DVD player should have outputs for audio to the speaker's. You can wire both units to the ignition harness for power and ground this to chassis.
dinki
Member - Posts: 7
Posted: May 22, 2004 at 11:56 PM / IP Logged
I have a pyle in dash 6.4 motorized i found you get what u pay for.  Even though you dont need an amp theres a hum.  Ovation told me an amp would fix the problem.  Hope this helps.
alicia4917
Member - Posts: 6
Posted: May 28, 2004 at 6:58 PM / IP Logged
you don't need an amp for these mate, i had mine both running off a double cigarette lighter connector and worked a treat until i did the stupid and probably the most stupidest thing ive ever done and connected a large magnet to the back of a 7'2" liliput flatscreen and i think its fubarred
thanks
c.a.t
71rb240z
Member - Posts: 14
Posted: June 30, 2004 at 4:16 PM / IP Logged
pyle dvd players gets hot, really fast. my buddy works at valor and they compare all kind of brand with their dvd players, and pyle is one of the fastest one to get above normal hot.
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
