amp junk?
bp_viper
Copper - Posts: 57
Posted: May 03, 2004 at 7:48 PM / IP Logged
i hooked up one of my amps today and anytime the power comes on it immediately shuts down. i know the wires were right and the sub was ok cuz i hooked up another amp and it worked fine. is the amp junk?
bp_viper
Copper - Posts: 57
Posted: May 03, 2004 at 7:50 PM / IP Logged
also sub is 4 ohm svc so amp should be able to run it
djMINIoompa
Copper - Posts: 125
Posted: May 03, 2004 at 7:57 PM / IP Logged
this may be a stupid question, but did you check all the wirers and connections? and the fuses on the amp or the inline fuse?
stevdart
Platinum - Posts: 5,816
Posted: May 03, 2004 at 8:12 PM / IP Logged
Check continuity of grounding.
flatulatta
Silver - Posts: 356
Posted: May 03, 2004 at 8:37 PM / IP Logged
sounds like if anything.... bad REM or fuses...
forbidden
Platinum - Posts: 5,354
Posted: May 03, 2004 at 8:46 PM / IP Logged
Disconnect the rca's and the sub, see if it turns on, then plug in the rca's, does it turn on, then the speaker leads, does it turn on.
bp_viper
Copper - Posts: 57
Posted: May 03, 2004 at 8:49 PM / IP Logged
where can you buy fuses if that is what it is
casedeez
Copper - Posts: 160
Posted: May 03, 2004 at 8:51 PM / IP Logged
I kinda dont think it would be anything to do with fuses. If a fuse is blown there is NO current going through it. Your amp wouldnt turn on and then off as far as I know. I had a problem similair a couple years ago. Mine was a bad ground. I found a new spot for the ground and hooked it up and it worked fine. Make sure on your ground that you remove any paint so you have a good connection. Also make sure whatever your grounding it to is grounded by the chassis of your vehicle. Im trying to think how a remote problem would play into this. One thing you might check on is your remote wire. If the wire insulation has been cut and is grounding out on something it might cause it to shut the amp off. I dont know for sure, maybe one of the stereo guru's can answer that. Just from the way it sounds to me is something is shorting out or you have a bad ground or both.
casedeez
Copper - Posts: 160
Posted: May 03, 2004 at 8:52 PM / IP Logged
Depending on the fuse you can generally buy them anywhere, via a hardware store. If your looking for something bigger or an inline fuse you might have to go to a stereo store.
bp_viper
Copper - Posts: 57
Posted: May 03, 2004 at 8:58 PM / IP Logged
well i know its not the ground, i got down to bare metal and secured it (plus the other amps worked fine) and i dont believe it was the remote (again, the other amps worked) i will try disconnecting everything and check to see if the power stays on and narrow it down tomorrow. thanks for the input
