2000 Nissan Frontier 2.4L
dmitchell84
Member - Posts: 14
Posted: May 05, 2004 at 1:46 PM / IP Logged
I've got a 2000 Nissan Frontier King Cab 2.4L and I'm looking for the VSS Vehicle Speed Sensor wire in order to hook up a navigation system.  Would anyone possibly be able to help me out?
rudbwoy69camaro
Silver - Posts: 350
Posted: May 06, 2004 at 1:01 AM / IP Logged
ItemWire ColorPolarityWire Location
12Vgreen+ignition harness
STARTERBLACK / YELLOW+ignition harness
IGNITIONBLACK/ white+ignition harness
ACCESSORYRED / yellow+ignition harness
SECOND ACCESSORYnone
TACHOMETERpink/blue or blackinstrument cluster or ECM *2
POWER LOCKyellow *7-*3
POWER UNLOCKyellow/red *7-*3
PARKING LIGHTS +blue/redsteering column
PARKING LIGHTS -none
DOOR TRIGGERRED / black *4-*3
HEADLIGHTSred, RED / blk *5+steering column
WIPERS*6-steering column
LF WINDOW UP/DNblue - blu/blkAat drivers door switch
RF WINDOW UP/DNblu/yel - blu/whtAat drivers door switch
LR WINDOW UP/DNnone
RR WINDOW UP/DNnone
TRUNK/HATCH PINnone
HOOD PINBLACK/ pink-*3
TRUNK/HATCH RELEASEnone
FACTORY ALARM ARMarms with lock
FACTORY ALARM DISARMdisarms with unlock
HORN TRIGGERlt grn/red or brown-steering column
BRAKE WIREBROWN / red+brake pedal switch
LOCK MOTORblue*3
UNLOCK MOTORGREEN / WHITE*3
DISARM DEFEATpurple or blu/red *9*3
DISARM NO UNLOCK*8
DOME SUPERVISIONnonenonnone
SPEED SENSEdk. GREEN/ black2ECM *2
SUN ROOF OPEN/CLOSEnonenonnone
SUN ROOF LIMITnonenonnone
LF SPEAKERnonenonnone
RF SPEAKERnonenonnone
LR SPEAKERnonenonnone
RR SPEAKERnonenonnone
RADIO 12Vnonenonnone
RADIO GROUNDnonenonnone
RADIO SWITCHnonenonnone
RADIO ILLUMINATEnonenonnone
POWER ANTENNAnonenonnone
Notes:*1 Not required for remote start. *2 The ECM is located below the heater box to the right of the accelerator pedal, behind trim panel. The tach is in the top row, 3rd pin left of center of the plug. The VSS is in the 2nd row from the top, 4th pin right of center. *3 Located at the Smart Entrance Control Unit above the hood release in the drivers kick panel. The door lock wires only meter when turn the key in either door key cylinder. *4 If equipped with factory dome light delay, use GREEN/ red(-) for the drivers door and GREEN/ black(-) for the passenger door. Diode isolate each wire. The RED / black may also be found in the drivers A pillar. *5 These wires are for the low beams. For the high beams use RED / green(+) and RED / white(+) at the same location. *6 Use WHITE/ blue for intermittent, WHITE/ red for low, and blue/white high. *7 Unlock requires a double pulse. On vehicles without the factory alarm, can also find lt. GREEN/ red for lock and brown for unlock. *8 A single pulse to the unlock wire will disarm the factory alarm without unlocking the doors. *9 It is purple on the 2 door models, and blue/red on the 4 door.
dmitchell84
Member - Posts: 14
Posted: May 06, 2004 at 6:12 PM / IP Logged
How do I access the ECM?  It seems impossible to get to...thanks
