Amp off factory Monsoon Radio?
carguy411
Silver - Posts: 683
Posted: May 07, 2004 at 1:39 PM / IP Logged
im trying to install just an amp off the factory monsoon radio. i used a loc off the back speakers and keep getting nothing i tried every speaker wire in the trunk and still nothin!!!!! y? what am i doing wrong. can someone please help me ASAP.
can i tap off the wires right from the amp in the trunk
please help!!!!!!!!!
kgerry
Platinum - Posts: 3,455
Posted: May 07, 2004 at 1:44 PM / IP Logged
no reason in the world it wouldnt work if you are tapping signal right off the speakers in the trunk.... which is obviously after the amp
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
carguy411
Silver - Posts: 683
Posted: May 07, 2004 at 2:01 PM / IP Logged
then y arent i getting any signal
its driving me crazy. i tried 2 diff amps and there barely moving the sub
DYohn
Moderator - Posts: 10,741
Posted: May 07, 2004 at 2:12 PM / IP Logged
Well, if they are "moving the sub" at ALL, then they are indeed getting a signal.  Sounds like you have not set up the voltage gains properly, both on your LOC and on your amp.
chriswallace187
Gold - Posts: 1,661
Posted: May 07, 2004 at 2:19 PM / IP Logged
Make sure you're tapping the woofer outputs and not the tweeter outputs, if you're doing it at the speakers. If that doesn't work you could try taking the wires from the radio to the amp.
dudek38
Copper - Posts: 250
Posted: May 07, 2004 at 4:46 PM / IP Logged
what type car? i tapped in to the speak wires on a new jetta just behind the rear pass door under the molding by the seat belt. there is a cluster of speaker wires. you have to take off the rear door panels to see which wires are the right color. splice your loc near there. this worked well for me.
owner of
Motion Marine & Car Audio
the florida keys
carguy411
Silver - Posts: 683
Posted: May 09, 2004 at 2:07 AM / IP Logged
it is on a 2003 pontiac grand am
theres a connector with 4 wires going to the speakers and then branches off to the speaker. sould i use that. which colors do i go for??
can the LOC be bad.? what if i would to take the RCA and cut it and go right to the wire and then run that to the amp??
please help
dudek38
Copper - Posts: 250
Posted: May 09, 2004 at 11:08 PM / IP Logged
if those wires are going the the rears, yes. find out which colors go where by actually looking at the speakers. wire them accordingly by left pos and neg and then the right.
no, use an loc. if u have "info"in those wires, then an loc will work. whether or not your loc is working , i dont know
owner of
the florida keys
carguy411
Silver - Posts: 683
Posted: May 09, 2004 at 11:38 PM / IP Logged
i dont have any info on the color codes for those wires i was just guessing. but i tappined into them and nothing happend. but i think the amp might be no good. its an old one that he had and thought worked so we are going to try a diff amp. hope it works soon
lol
kgerry
Posted: May 10, 2004 at 9:08 AM / IP Logged
i've always found it good to start an install with a few "known goods".... like good wiring info on what wires you are tapping into, an amp that you know works, etc., etc.        this will eliminate the whole " Frial & Error " approach you seem to have taken
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
