Tach Wire For 2001 Camry
Welcome Guest :)
hayvevoianh
Member -
Posted: May 09, 2004 at 3:14 PM / IP Logged
Can anyone help me find the tach wire for the 2001 Toyota Camry and its location thank you.
rudbwoy69camaro
Silver -
Posted: May 09, 2004 at 6:52 PM / IP Logged
2001 Toyota Camry | Item | Wire Color | Polarity | Wire Location |
| 12V | white - WHITE/ red | + | ignition harness |
| STARTER | red | + | ignition harness |
| IGNITION | BLACK / YELLOW | + | ignition harness |
| ACCESSORY | blue/red | + | ignition harness |
| SECOND ACCESSORY | BLACK/ red *1 | + | ignition harness |
| TACHOMETER | black or gray *2 | | *2 |
| POWER LOCK | dk. blue/white *3 | - | org plug bottom of fusebox |
| POWER UNLOCK | dk. blue *3 | - | org plug bottom of fusebox |
| PARKING LIGHTS + | green | | bottom of fusebox *4 |
| PARKING LIGHTS - | green | | steering column |
| DOOR TRIGGER | RED / white | - | top of fuse box *5 |
| HEADLIGHTS | RED / yellow | - | steering column |
| WIPERS | | | |
| LF WINDOW UP/DN | green - red | A | drivers door switch |
| RF WINDOW UP/DN | grn/wht - RED / blu | A | drivers kick panel |
| LR WINDOW UP/DN | grn/yel - RED / yel | A | drivers kick panel |
| RR WINDOW UP/DN | grn/blk - RED / blk | A | drivers kick panel |
| TRUNK/HATCH PIN | RED / yellow | - | light or sw. in trunk |
| HOOD PIN | | | |
| TRUNK/HATCH RELEASE | | | |
| FACTORY ALARM ARM | arms with lock | | |
| FACTORY ALARM DISARM | disarms with unlock | | |
| HORN TRIGGER | GREEN/ black | - | steering column |
| BRAKE WIRE | GREEN / WHITE | + | bottom of fusebox *4 |
| LOCK MOTOR | blue/red | | org plug bottom of fusebox |
| UNLOCK MOTOR | blue | | org plug bottom of fusebox |
| DISARM DEFEAT | blue/black | | org plug bottom of fusebox |
| DISARM NO UNLOCK | blu/blk (key sense) | - | ignition harness |
| DOME SUPERVISION | none | non | none |
| SPEED SENSE | none | non | none |
| SUN ROOF OPEN/CLOSE | none | non | none |
| SUN ROOF LIMIT | none | non | none |
| LF SPEAKER | none | non | none |
| RF SPEAKER | none | non | none |
| LR SPEAKER | none | non | none |
| RR SPEAKER | none | non | none |
| RADIO 12V | none | non | none |
| RADIO GROUND | none | non | none |
| RADIO SWITCH | none | non | none |
| RADIO ILLUMINATE | none | non | none |
| POWER ANTENNA | none | non | none |
| Notes: | NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555F or 555U to bypass. *1 There are two BLACK/ red wires going to the same pin at the plug. use either one. *2 On the 4 cylinder motor use the black wire in the gray plug at the coil on the drivers side of the motor. On the 6 cylinder motor use the gray wire located at the ignitor on a bracket just in front of the strut tower. The module says Denso on it. *3 The lock wires are about 18 gauge. They will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself. *4 In a white connector just below the fuses with the wires exiting out toward you. *5 Located in a seven pin plug on the top right side of the fuse box. |
hayvevoianh
Member -
Posted: May 09, 2004 at 8:50 PM / IP Logged
Wednesday, May 13, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
