Overpower vs Underpower Sub?
mrdragon
Copper - Posts: 121
Posted: May 12, 2004 at 4:26 AM / IP Logged
Guys need some info on what do u mean by underpower the sub?? I am thinking of gettting 2X 12" they are rated at 150WRMS each and i was thinking of driving each sub with 75WRMS is that work ok, or should i just buy 1 sub and use 150WRMS to drive it??? Which give better result??
Cheers :)
doc t
Copper - Posts: 169
Posted: May 12, 2004 at 5:08 AM / IP Logged
in a matter of speaking, in my opinion, it is always better to overpower a sub vise underpower it. i'm driving my 2 subs @ 550wrms and there rated @ 150wrms each, have always done this with no problems.
        T
forbidden
Platinum - Posts: 5,354
Posted: May 12, 2004 at 1:53 PM / IP Logged
You can underpower a sub all day long as long as the gain is set properly and the system is used properly. If you want it louder, find a bigger amp.
nottelling
Member - Posts: 13
Posted: May 12, 2004 at 3:35 PM / IP Logged
i have 2 200 watt rms subs any opinons on how much power they should have put to em?
DYohn
Platinum - Posts: 10,741
Posted: May 12, 2004 at 3:38 PM / IP Logged
What's their make/model and what kind/size of enclosure are they in?
djMINIoompa
Copper - Posts: 125
Posted: May 12, 2004 at 7:13 PM / IP Logged
back to mrdragon's question....There are more cases of blowing subs from underpowering them. However, forbidden makes a very valid point. You must set the gain right. Whether over powering or under powering, you still ahve the same chance to blow the subs if the gain isnt set properly. I would rather have more power, this not only get the full potential out of the subs, but it also gives you room to expand and upgrade your system.
pureRF
Silver - Posts: 619
Posted: May 12, 2004 at 10:18 PM / IP Logged
are they SVC or DVC and are they 2 or 4 ohm?
dream it, build it, fiberglass it
xetmes
Silver - Posts: 586
Posted: May 12, 2004 at 10:23 PM / IP Logged
Exactly. I really hate the term "underpowering", it has nothing to do with the power, if the amplifier is not clipping there is no problem. The clipping of the amp is what causes the destruction of the speaker, keep the signal distortion free and you can run a 30 inch sub at one watt forever..
mrdragon
Copper - Posts: 121
Posted: May 13, 2004 at 1:43 AM / IP Logged
Ok how do u set the gain properly?? the sub i am thinking of getting is a 4 Ohms SVC.
Cheers :)
casedeez
Copper - Posts: 160
Posted: May 13, 2004 at 2:15 AM / IP Logged
Hey mrdragon, take a look at my most recent post. I list three differant ways to do it, as far as which way is the best, I have found thats hard to find here. Your best bet may be to do a search either on here (you'll find two posts about setting gain) or google it. The JL audio page has some tutorials but it has a lot to do with thier amps. If by chance your able to uncover something which I havnt found by all means please let me know.
I hope this helps at least a little bit.
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
