remote start wiring diagram
Ray562
Member - Posts: 12
Posted: August 31, 2002 at 3:23 PM / IP Logged
Was up everyone i need a wiring diagram for a 2001 Chevrolet Suburban, to add a remote start. I already have an alarm. Thanks in Advance
Ford Motor Company Alarm Tech
Platinum - Posts: 12,488
Posted: August 31, 2002 at 9:41 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |brown plug at BCM *1        |
|     POWER UNLOCK|white               |+  |brown plug at BCM *1        |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |lt. blue plug at BCM *1     |
| PARKING LIGHTS -|white               |   |lt. blue plug at BCM *1     |
|       HEADLIGHTS|white               |+  |lt. blue plug at BCM *1     |
|     DOOR TRIGGER|*2                  |-  |BCM *1                      |
|FCTRY ALRM DISARM|lt.green            |-  |drivers kick *4             |
|       TACHOMETER|white               |   |ECM *3                      |
|      SPEED SENSE|dk.GREEN / WHITE      |   |ECM *3                      |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |brown plug at BCM *1        |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue   -   brown    |A  |drivers door switch         |
|  RF WINDOW UP/DN|blue   -   brown    |A  |passenger door switch       |
|  LR WINDOW UP/DN|blue   -   brown    |A  |LR door switch              |
|  RR WINDOW UP/DN|blue   -   brown    |A  |RR door switch              |
Notes:
Note:  This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. .  Note: Diesel glow plug, dk. blue(-) located at the instrument cluster.  *1 The BCM is located behind the drivers side of the dash.  The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.  *2 Use tan for the drivers door located in pin B4 of the purple plug, the passenger doors are a blue/white in the lt. blue plug, and the rear hatch pin is a pink/black in the lt. blue plug. You must diode isolate these wires.  *3  ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled "red", and VSS wire is at pin 3 in the connector labeled "black". On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the "red" connector, and VSS wire is located in pin 50 of the "red" connector.  *4  Also found in the purple plug of the BCM.
