How to flash parking lights on a Mercedes?
Turbo W124
Posted: August 31, 2002 at 8:47 PM / IP Logged
As you know, there are seperate wires for the left and right parking lights.
Can someone post a diagram or at least let me know what relays I should use? My module only has one 12v output (i wish it had dual) for the parking lights. Thanks!
Platinum - Posts: 12,488
Posted: August 31, 2002 at 9:14 PM / IP Logged
two relays are required for an independent parking light circuit:
Relay # 1:
  • 87 & 85 : Light Output from alarm/RS unit
  • 86 : Ground
  • 30 : To left side of parking lights
  • 87a: NOT USED
Relay # 2 :
  • 86 : Ground
  • 30 : To right side of parking lights
  • 87a: NOT USED
Chris Luongo
Platinum - Posts: 3,746
Posted: September 01, 2002 at 7:59 AM / IP Logged
Just split the alarm's parking light output with a pair of six-amp diodes.
Tie the alarm's parking light outputs to one end of both diodes.
Now you have one end of each diode left over; these go out to the left and right parking lights in the car.
(I can never remember which way to orient the diodes.  Just try it temporarily by holding the diodes in place with your fingers, and then reverse them if the parking lights don't work.)
Jeff's setup with the two relays will also work fine, but in my opinion, it is too expensive and inconvenient.  Relays will cost anywhere from $2-20 each depending on where you shop, plus the labor to wire them up and mount them.  You can get a whole package of diodes for a buck or two.
You do suffer a very slight voltage drop with the diodes.  The parking light flash will be just slightly less bright than if you'd used the relays; not enough to even notice.  And, of course, when you use the normal light switch on the dash, they'll still work just as brightly as ever.
Posted: September 01, 2002 at 8:59 AM / IP Logged
Hey Chris.... he/she drives a Mercedes.... I don't think $$$$ really makes a difference to him/her How to flash parking lights on a Mercedes? -- posted image.. I never thought of using the diodes and splitting the parking light wires How to flash parking lights on a Mercedes? -- posted image.. I've always used 2 relays just to be sure as diodes have a higher tendency to burn out than relays.
