Polarity confirmation on Focus
JakeGreenfield
Posted: May 19, 2004 at 3:48 PM / IP Logged
Hi,
I'm a newbie and apologize it this had been discussed ad nauseum. but..........
I checked in the wiring database and there was no into for my car.
I have a 2003 Ford Focus (4 door) with Visteons 6006 head unit.
I'm switching out the speakes only and need confirmation of polarity of oem wiring.
Information I have indicates the following  Front Speakers: White (+),  Grey (-)
        Rear Speakers: WH / VT (+), GY / WH (-)
Is this info correct?
Thanks,
Jake
raydawg357
Silver - Posts: 769
Posted: May 19, 2004 at 5:41 PM / IP Logged
You are correct.  The whites are positive and grays are negative for each speaker
Do it right the first time
JakeGreenfield
Posted: May 21, 2004 at 9:19 AM / IP Logged
Thanks much, man.  I have them installed and they sound terriffic.
I switched out the oem speakers ( which are tolerable) for Boston Acoustics FX8's.
BTW, I put them in all four doors.  4:5 audio people I spoke with told me it was a waste of money to put new speakers in the rear doors.  Is this because they assumed I would have a sub-woofer in the rear of the car?
Also, I put some dynamat in the doors.  Not full sheets but around the speakers, behind the speakers and a few squares in large areas of the doors.  Probably won't win awards, but its the best sound I've ever had in a car.
Jake
Ravendarat
Platinum - Posts: 2,806
Posted: May 21, 2004 at 10:29 AM / IP Logged
Boston make great speakers and Im sure you will be very happy with them for a long time. Regardless of what people tell you, when it comes to sound all that matters is that you and your ears are happy.
JakeGreenfield
Posted: May 21, 2004 at 6:57 PM / IP Logged
True that.  As I become more accustomed to the Bos Acc, I do wish they had more mid-range.  The tones, bass and treble,  are full and crisp, but  seem over power the mid range, most notably the vocals.  Local audio guys love the sound of my speakers but explained that what I'm probably noticing is the limitation of the OEM head unit to keep the tracts distinct.  They tell me an amplifyer will "clear up" the sound, probably to my likeing..
That would be expensive.  I'd need an amplipher for 4 channels so I could fade, plus a cross-over unit (or some such device) at any rate one shop said it would be around $300 installed..  New head unit with better amplipher makes more sense.
However, I got some advice that cost nothing to implement.  This guy said speaker location has a great deal to do with enjoyment and car companies make cars not sound systems, so the speaker placement is ususlly less than ideal.  He suggested I move the balance toward the drivers side 2-3 places and fade the sound towards the front 2 places.  That made a noticable difference.  The sound tracks sound more distinct and vocals more present.
I think that is all I'm going to do for now.  The speakers are amazing even if the head unit is less than the bestl.
customsuburb
Gold - Posts: 1,813
Posted: May 21, 2004 at 9:36 PM / IP Logged
An amplifier would greatly improve the sound of your Boston speakers. A small amp like this Hifonics one would be a not too expensive upgrade that would improve your sound alot. You can use two LOCs and use the built in crossover and your total install would come to about $150 for everything (an amp kit and the two LOCs). Then the next upgrade you could make would be either a sub or a new cd player.
JakeGreenfield
Posted: May 22, 2004 at 11:59 AM / IP Logged
Thanks for the advice and the link, Customsuburb.
Not only are the specs impressive on the Hifonics amp. but the size appeals to me as well.  I like to keep my interior with an understated look and that amp looks like it could fit under the seat, or hidden somewhere.
