benefiets of poyfil
slow_hoe2001
Member - Posts: 42
Posted: May 19, 2004 at 9:08 PM / IP Logged
i have sealed sub boxes and i was told i could get a lil more noise out of them by adding polyfil. they said 1 pound of fil would be equal to adding 1 cube to the box. is this true? i was also told this would just make the bass more "boomy"     which is true
auex
Platinum - Posts: 5,041
Posted: May 19, 2004 at 9:12 PM / IP Logged
Hell no, that is not true. At most a lightly stuffed box may add up to 20% more volume. Whether you need to add any polyfil or not will depend on the size of your box and the amount of airspace your subs like.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
thapimpfromchi
Silver - Posts: 616
Posted: May 20, 2004 at 12:01 AM / IP Logged
Polyfil is only good in a few situations. Are your sub boxes built to spec? if so, you shouldnt use any. As auex said, HELL NO, you arent going to add one cube by adding 1lb of polyfil. Why would you want to add another foot anyways? If your box is a little smaller than it should be, then adding some polyfil might help you out. If the box is built to spec, or larger than spec, you dont want polyfil. some people say you can gain 20% others say 40%. I'm not sure what the real number is, but you sure as hell dont get 100% Good luck,
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
