compustar cm3000 ground output when armed
wire4veins
Copper - Posts: 97
Posted: May 26, 2004 at 12:33 PM / IP Logged
we installed a CM3000 yesterday and having a tough time with the ground output when armed bleeding off the ignition since this wire is connected to the starter kill anti grind relay and they did not put a diode on the relay. We tried running a diode across 85 (ignition) and 86 (G.O.W.A) and its still getting a bleed through of ignition to the window module? Any ideas?
wire4veins
"D"
Precision Autosound - Owner
MECP Master Installer
Platinum - Posts: 12,488
Posted: May 26, 2004 at 1:01 PM / IP Logged
What size diode did you use ? If the diode doesn't work, then use a relay from the GOWR to trip a relay for the starter kill wire.
wire4veins
Copper - Posts: 97
Posted: May 26, 2004 at 4:37 PM / IP Logged
Thanks that worked using the GOWR on the starter antigrind relay. Thanks again.
wire4veins
Car Trix
Ogden, Utah
wire4veins
"D"
Posted: May 26, 2004 at 5:55 PM / IP Logged
No problemo compustar cm3000 ground output when armed -- posted image.
