Alt./Elec. Prob, Tried so many things
specialblendj
Copper - Posts: 118
Posted: May 26, 2004 at 11:31 PM / IP Logged
Alright, I have an electrical problem with my 1997 Honda Civic DX.  It's not my battery (which is only a couple months old).  The whole thing started with my headlights starting to dim.  It seemed to do it mainly at night after the car had been sitting for a few hours, and in the morning, again after it had been off for several hours.  The dimming of course became worse with the use of accessories such as the air conditioner or stereo.  My check engine light also came on and it would dim also.  Around the same that all this started happening, my speedometer started going crazy, jumping up and down all the time.  So I'm getting ready to add some amps and planned on upgrading the alternator anyways, so I do what any cheap ass would do and I hop on ebay and order myself a 135 amp alternator from alterstart.  I get it, do the swap myself (this was my first time) and the only difference was that now my speedometer didn't work at all, absolutely no movement.  Check engine light was still on, and this alternator appeared worse than the original.  Now the car is useless.  So I pay 16 bucks to mail this thing back to alterstart in texas (after having a shop test it and tell me that it was bad of course) and they return it to me saying that they fixed it.  So I put it in again, and it still doesn't work.  I had previously charged my battery for a few hours, so the alternator appeared to work, until my car died at an intersection the next day.
I have re-grounded my battery, and my engine.  My alternator grounds through the engine.
I have not ran a new positive power wire to my alternator, I plan on doing this once I fix my problem, but the stock one seems to be in very good shape.
I have checked the brushes and the Diodes in my new alternator, they each seem fine.  I didin't know what to look for, or how to test a diode with my digital multi meter, but the brushes are still plenty long and are making good contact with the spinning metal rod, and the diode (I only say one in my new one, as opposed to three in my old one) looks fine.  It has no breaks or burn marks.
The pulley is tight, and the harness plugged in.
Today I had the alternator checked by Kragen, it passed there machines test, but I got a second opinion from the alternator shop who had before said it was bad, and they said it worked, but the charge light stayed on.  In other words the machine said that it would work, but when I throw it in my car my battery light on the dash will be lit.  He said it could be a bad voltage regulator, which is built into the alternator.  Today I dissasembled the whole thing and didn't notice anything obviously wrong.  I have no experience with alternators, I worked as a car audio installer for about 10 months now, but not at a place that installs alternators.
If nobody here knows of anything else I can try, I will have some choices to make tomorrow.  Alterstart claims no cash refunds, and the electrical shop says it'll cost 70 bucks to diagnose my electrical problem.  If it is the power regulator, they'll just tell me to get a new alternator.  If I want to send it back to alterstart for warranty repairs again, I'll once again have to pay for shipping.  Preferrable I would be able to isolate the problem, then say look, You pay shipping both ways, cause I already shipped it back once and you said you fixed it.  I just want to be able to say whats wrong with it, so they dont say its not the alternator.  Or maybe it isnt the alternator, but I dont know what else it could be.
Thank you for any help, and sorry about the long post.
DYohn
Platinum - Posts: 10,741
Posted: May 26, 2004 at 11:42 PM / IP Logged
Unfortunately I have to agree with the alternator shop.  It sounds very much like a bad alternator or a bad voltage regulator.  A Honda shop with the right computer diagnostic equipment might be able to tell you for sure.  But it sounds like you did the right thing by trying to go for a larger alternator, but are getting hosed courtesy of Alterstart.  Tell them you are getting really pissed and you demand they send you agood alternator with a goood voltage regulator built in.  (they probably won't care, but it always feels better to yell and scream and make demands on retailers who are ripping you off.)
BTW, to check a diode with a DMM requires that you remove it from the circuit.  Set the DMM on the diode scale if it has one, or on the lowest ohms scale if it doesn't.  A properly functioning diode will indicate less than an ohm with the meter leads connected across the diode in one polarity, and an open circuit when you reverse the polarity (swap the leads position.)
specialblendj
Copper - Posts: 118
Posted: May 27, 2004 at 5:33 PM / IP Logged
OK so I called alterstart today, and explained the situation to them.  I got them to give me a new alternator altogether, and a 150A instead of a 135A, which is a $50.00 upgrade.  Plus they are going to pay shipping both ways to get alternator I have back, and get me the new one.  So I basically got about 65 bucks out of em, which doesnt even cover my insurace for the time I've been out of a car, but o well.  I'm happy I got something and soon this will all be over.
I would just like to say that this has been my first negative online shopping experience.  I here people bashing online/ebay sales all the time, and they have there points, but I have never had a problem until now.  I have purchased thousands of dollars worth of products online, including a deck, amp, sub, 2 sets of speakers, a camera and a lens, and more, and this is my first regretful experience.
auex
Platinum - Posts: 5,041
Posted: May 27, 2004 at 5:54 PM / IP Logged
Looks like some one forgot to use his nifty quote feature. Buy yeah sounds like it may be in the alt but you are getting a new one so it should work out.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
forbidden
Platinum - Posts: 5,354
Posted: May 27, 2004 at 6:05 PM / IP Logged
Hahaha, I was thinking at first wow man, bang bang has been a closet car audio guy all along and was playing us, then I noticed the strking similarity to another post above. Nice one dude, almost got me.
Alpine Guy
Platinum - Posts: 2,478
Posted: May 27, 2004 at 6:12 PM / IP Logged
You should defintely run a 4 awg power wire from your alt to your batt now, and still leave the factory wires attached.  the power rateing of your new alt will definately melt your factory wires if you leave it alone.
specialblendj
Copper - Posts: 118
Posted: May 27, 2004 at 11:56 PM / IP Logged
The way my wiring is currently set up is, the positive wire runs from my alternator, to the fuse box, to the battery.  Should I run a larger power wire in this same way, or just go straight from the alt. to the battery.  And of course I have every intention of upgrading the power wire.  I plan on pulling from 1200 to 1400 watts rms, going by the amps power ratings.  Of course normal use will not use this much.  I know 7th generation civic have their transmissions grounded, should I upgrade this as well.  What grounds through the transmission?
specialblendj
Copper - Posts: 118
Posted: May 28, 2004 at 2:15 PM / IP Logged
anyone?
auex
Posted: May 28, 2004 at 4:06 PM / IP Logged
There is no reason to replace the current wiring, unless corroded. I would however add another wire directly from the alt to the battery. As far as the ground goes, I just replaced the chassis to battery ground with some 2 gauge and it worked nicely.
