94/95 nissan primera alarm bypass
alicia4917
Member - Posts: 6
Posted: May 28, 2004 at 12:56 AM / IP Logged
hi to all
i really need a way of bypassing the immobiliser (flashing led) on my 94/95 nissan primera eGT please please its been sat for 3 weeks now and i cannot afford the prices that nissan have offered me thanks
carl
c.a.t
jfk51502003
Copper - Posts: 221
Posted: May 28, 2004 at 5:08 PM / IP Logged
IS YOUR CAR NOT CRANKING...?DOES EVERYTHING ELSE WORK...DO YOU STILL HAVE REMOTES FOR ALARM...WHAT PRICES COULD NISSAN GIVE YOU...FOR WHAT PROBLEM...?NEED MORE INFO...ALTHOUGH IT SOUNDS AS IF YOU HAVE A STARTER KILL IN LINE...(ON STARTER WIRE)AND IT IS NOT ALLOWING VEHICLE TO START...????
jfk51502003
Copper - Posts: 221
Posted: May 28, 2004 at 5:13 PM / IP Logged
EVERYTHING ELSE WORKS... ITS JUST NOT CRANKING...????NEED MORE INFO...????
alicia4917
Member - Posts: 6
Posted: May 28, 2004 at 6:16 PM / IP Logged
here goes...
when i bought car the i was given 2 keys and one key fob,
one of the keys works the glovebox only the other key was snapped in the ignition,that one still woked the ignition because the other half of the key was still in the ignition but it did not work the drivers sid door and also there was no boot lock so my guess was maybe the car was broken into at some point but i asked no questions because i got the car for £500 with 121.000 on the clock and leather interior and all electrics working which i thought was a real bargain but now yhe key fob has been misplaced of which i was relying on to lock/unlock athe car and also disable the what i think is a factory fitted alarm
and i don't no what to do please can you help in any way thanks carl
c.a.t
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
