Painting fiberglass
Duby
Member - Posts: 14
Posted: May 30, 2004 at 7:44 PM / IP Logged
I'm fiberglassing the rear deck of my car and am planning to paint it. What grit should I go up to?
$4000 stereo in a $1000 whip, thats how u do it
audiomechanic
Silver - Posts: 388
Posted: May 30, 2004 at 8:41 PM / IP Logged
50 - 80 grit then poly prime.
sand the poly primer to 320 or 400 then surcace prime it.
then sand the surface coat to from 400 to 800 grit.
base then clear.
Duby
Member - Posts: 14
Posted: May 30, 2004 at 10:59 PM / IP Logged
Aight. I know what primer is but what is the poly and surcace and where do I get it?
audiomechanic
Silver - Posts: 388
Posted: May 31, 2004 at 10:18 AM / IP Logged
the poly primer is a high build polyester primer. the surface primer is the last thin layer of primer that is applied and sanded before the color is applied
both can be purchased at any bodyshop supplier.
Duby
Member - Posts: 14
Posted: May 31, 2004 at 1:49 PM / IP Logged
Ok. It's surface. I was wondering what surcace was. Thanks a lot.
djdaveoc
Copper - Posts: 231
Posted: June 05, 2004 at 12:48 AM / IP Logged
You couldn't figure out surcase?  lol, sorry but lol
Painting fiberglass -- posted image. Plan, Research, Do
