Port Tuning, Hz?
Copterdr
Posted: June 02, 2004 at 9:48 PM / IP Logged
I just built 2 seperate boxes to maximize my space and they are for 10" Punch.
I went to 12 volts site to see what was the volume of these and now i THINK i MAY  Port them... I have .80566    as the volume per sub in the enclosures, How big should my port be?
I am pushing them with  a Punch P3001 rated power is 300 W  RMS x 1@2 OHMS... how do I figure Hz to get the size and length of the ports?
HELP ME PLS
Thanks ALWAYS for the help
auex
Platinum - Posts: 5,041
Posted: June 02, 2004 at 10:07 PM / IP Logged
.80 cubic ft? That is way to small of a box to port.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
stevdart
Platinum - Posts: 5,816
Posted: June 02, 2004 at 10:09 PM / IP Logged
Use the sub manufacturer's exact, specific size requirements if you want to port.  They will tell you what to use.  You can look up your model here.
Copterdr
Posted: June 02, 2004 at 10:37 PM / IP Logged
Thanks for the help guys... If i port them yes they are too small however a sealed looks like they are too big...is that a problem on sealed boxes? Will .15 be a problem for the speakers on a sealed box?
stevdart
Posted: June 02, 2004 at 10:47 PM / IP Logged
A box that is too big can be filled to the right size.  Double panels, put in bracing, glue in a wood block, etc.  Do a lot of measuring, and get it to the recommended air space.
Copterdr
Posted: June 02, 2004 at 10:53 PM / IP Logged
ok cool but what does it do to the speakers being too big... just laymens terms...will it freeze the voice coils?
will poly filling it help take some space?
Ravendarat
Platinum - Posts: 2,806
Posted: June 02, 2004 at 11:32 PM / IP Logged
Poly fill will actually do the oposite, you wanna use a wood block
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
