2002 Dodge Ram Audio Wiring
rkbpos
Posted: September 04, 2002 at 4:48 PM / IP Logged
I'm looking for the audio wiring schematics for a 2002 Dodge Ram 1500 Regular Cab.  I've seen some posted on other sites, but they are incorrect.
I've only checked one speaker so far and found that the Right Front is:
+ GREEN/ Light Green
 - GREEN/ Red
If anyone could help me out with the rest, I would really appreciate it.
Thanks,
RKBPOS
karbon14
Posted: September 04, 2002 at 4:52 PM / IP Logged
RADIO 12V |pink                 | +  |radio                       |
|        RADIO GROUND |BLACK/ green          | -  |radio                       |
|        RADIO SWITCH |BROWN / red            | +  |radio                       |
|    RADIO ILLUMINATE |ORANGE / blue (dimmer) | +  |radio                       |
|          LF SPEAKER |lt grn/rd-lt grn/grn |    |radio or amplifier *6       |
|          RF SPEAKER |lt blu/pu-lt blu/blk |    |radio or amplifier *6       |
|          LR SPEAKER |wht/red - wht/blk    |    |radio or amplifier *6       |
|          RR SPEAKER |tan/pur - tan/blk    |    |radio or amplifier *6       |
*6 The amplifier is located behind the glove box.
rkbpos
Posted: September 04, 2002 at 4:54 PM / IP Logged
You're Awesome!
Thanks!!!
BigBlue2002
Posted: November 20, 2002 at 8:12 AM / IP Logged
Couple of questions.. according to your diagram, it doesn't state the + or - wiring colors for the speakers.  Can you list those?
Also, the door wiring doesn't match the wiring you have listed.  I know the back quad cab speakers are as follows
RR WHITE/ red tracer  WHITE/ black tracer
LR WHITE/ red tracer  WHITE/ black tracer (yes both sides are the same colors)
The rear is as follows:
RF lt blue/red tracer  lt blue with/black tracer
LF Lt GREEN/ red tracer Lt GREEN/ dark greentracer
Am I to assume that the red tracer is (+) and the black tracer (or dark green) is (-)?
Help!
Rob Robinson
2002 Ram Quad Cab Sport
BigBlue2002
Posted: November 22, 2002 at 5:26 AM / IP Logged
No one out there change the speakers of a 2002 Quad Cab Ram???
Rob Robinson
Gentleman
Copper - Posts: 71
Posted: November 22, 2002 at 1:36 PM / IP Logged
This is from the 02 Dakota FSM but might help
LB/R    +
LB/BK   -
LG/Red   +
LG/DG    -
WT/RD   +
WT/BK   -
TN/RD   +
TN/BK   -
The Left rear in the book does not agree with what you posted.
DeathsJester12V
Silver - Posts: 352
Posted: November 22, 2002 at 1:42 PM / IP Logged
hey next time Big blue....just look at the Speaker HArness on the Speaker...if you see an A or B...might have to unplug it...the A is positive and the B is negative...or you can pop the speakers to find out which is which.....just a litle hint for ya, nothign more...
Đễẳ†ђş 12\/ Ĵęśŧē®™
BigBlue2002
Posted: November 22, 2002 at 3:51 PM / IP Logged
Thanks for the 2002 Dakota info.  Seems to match up pretty close.  I tried looking for any type of marking, but there wasn't any.  What really threw me was that the "plug" had the positives on one side for the rear and the positives on the opposite side for the front.  i was afraid I had one or the other reversed, but it is nice to know I didn't.  Thanks for the help!
Rob Robinson
2002 Ram
Rob Robinson
DeathsJester12V
Silver - Posts: 352
Posted: November 22, 2002 at 6:10 PM / IP Logged
Oh yeah....and manufacturers for some reason do that...Like on GM's...the light colored wire is positive, and the dark negative on the front speakers, and on the rear it's opposite...( or is it the other way around???) anyhow...don't know why they do it, they just do, and it looks like Dodge has done it to...if you're ever in doubt man...cut the speaker  and harness off ( make sure you leve enough to splice it back together, for when you ditch teh vehicle ) and pop the speaker...easy way to find positive and negative...seems like more work, but better than waiting for one of us to respond sometimes...
Well goodluck, and if you're done Congrats...
Đễẳ†ђş 12\/ Ĵęśŧē®™
BigBlue2002
Posted: November 23, 2002 at 2:09 PM / IP Logged
Well, the strange things continue.  I went and did the speaker pop thing  since I cut off the harness and left it connected to the factory speakers.  I found out that if that is right, then either the factory hooked up the factory speakers backwards (the red on + made them pop inwards) or all the wiring we have been talking about is completely backwards.. I tested each speaker with the factory plug and wire colors attached, and EVERY SPEAKER popped opposite than it should have.  Now what???
So, I went back and reversed all the new speakers.  I now get a little less highs (it was almost earpearcing at time with no amp) and the bass is coming in stronger on all speakers... so  what do you guys think?  Do you think Dodge would honestly make every wire with a red tracer - and every wire with a dark tracer +?  Or do you think the factory speakers would just be wired wrong???
Would you think it would hurt the head unit if I have them backwards now?
Any suggestions would be appreciated..
Rob Robinson
Saturday, January 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
