flashing headlight led
revmatt99
Member - Posts: 28
Posted: June 05, 2004 at 5:38 AM / IP Logged
I was curious as to whether anyone here had installed the l.e.d.s in the head or tailights. Do they install easily.. do they look cool.. or are they not even worth the time.. thanks.. sounds like a neat idea..flashing headlight led -- posted image.
auex
Platinum - Posts: 5,041
Posted: June 05, 2004 at 11:22 AM / IP Logged
Yeah, they are easy to do. I would however only do the tail lights, if you drill into the headlight housing then you get condensation and it sucks. If you do the tail lights, drill and place the led in the reverse light area where it is somewhat clear for better visibility.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
