Install messing up your car?
windcalmer
Member - Posts: 31
Posted: June 05, 2004 at 4:31 PM / IP Logged
Has anyone ever had their audio system mess up their cars computer or anything that would cause the car to not to shift right?
Joan
"But the sons of men fought on, and slew; and Eris (Strife incarnate) gloating watched." - Quintus Smyrnaeus
jfk51502003
Copper - Posts: 221
Posted: June 05, 2004 at 5:14 PM / IP Logged
IM GUESSING YOU INSTALLED SOME SORT OF CAR AUDIO COMPONENT...WHAT EXACTLY...WHAT TYPE OF VEHICLE... ...?
Alpine Guy
Platinum - Posts: 2,478
Posted: June 05, 2004 at 6:34 PM / IP Logged
Holey cap lock bat man!   If you have a 2000 or newer GM, ,then ya, , you need a special harness.
lspker
Silver - Posts: 503
Posted: June 05, 2004 at 7:01 PM / IP Logged
We've installed a Varad Scanner on a 2000 Dodge minivan.  Tied into radio wires, once in a while the tranny indicator would show only park,  would go in 1st gear only.  Pulled out the light, tranny works fine.  Are these newer car senative to changing ground signals, you beatcha.  But if you installed with a proper harness it should work fine.
auex
Platinum - Posts: 5,041
Posted: June 06, 2004 at 3:15 AM / IP Logged
That would be more of a remote start type issue then an audio related issue. It is possible buy highly unlikely that just replacing the radio would cause something like this.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Wednesday, November 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
