1999 Mazda Millenia factory alarm
quedog
Posted: June 05, 2004 at 5:00 PM / IP Logged
Need help bypassing factory alarm when using remote start and trunk pop feature.   Most info say connect to lt GREEN/ red wire in driver side harness but when I do that the factory alarm still goes off and prevent starting, when I put the key in the door and unlock which bypasses the factory alarm it starts but If i hit the disarm button it kill the car and some funky stuff happen.
I also read to tie into the key sense wire with a positive trigger which didn't really work either but is not a good idea with this car because the key sense wire also makes the steering wheel comes down in this car which is fine when remote starting but every time I hit the unlock button the triggers the steering wheel to move.
Thanks,
Any help is appreciated,  Q
jfk51502003
Copper - Posts: 221
Posted: June 05, 2004 at 5:41 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - MAZDA / MILLENIA / 1999 / Remote Start
[PRINT THIS PAGE]
12voltsgreen + ignition harness
Notes: Also found in a white plug in a silver box next to the firewall above and behind the fusebox: 12V-WHITE/ red; starter-BLACK / YELLOW 12awg; ignition-BLACK / YELLOW 18awg.
StarterBLACK / YELLOW + ignition harness
Second Starter
IgnitionBLACK/ white + ignition harness
Second IgnitionBLACK/ red + ignition harness
Third Ignition
Accessoryblue + ignition harness
Second Accessory
Keysense
Power Lockblu/red or orange passenger door harness
Power Unlocksame wire passenger door harness
Lock Motorred drivers kick panel
Unlock Motorblue/black drivers kick panel
Parking Lights+orange drivers kick
Notes: In a large harness to the rear of the car.
Parking Lights-lt. green or RED / yel steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Triggerlt. green - drivers kick
Dome Supervision
Trunk/Hatch Pinred - drivers kick
Notes: Rest at ground with the key off. Diode isolate to keep ground from feeding back from the indicator lamp.
Hood PinBROWN / white - top of fuse box
Notes: In a 20 pin green plug.
Trunk/Hatch ReleaseBROWN / white + drivers kick
Notes: In the harness coming in from the drivers door.
Power Sliding Door
Factory Alarm Armarms with lock
Factory Alarm Disarmdisarms w/ unlock
Disarm No Unlocklt GREEN/ red or - drivers door harness
Notes: Negative trigger through a 1K (1000 ohm) resistor will lock the doors and arm the factory security. Negative trigger on the same wire will unlock all doors and disarm the factory security. Test using the passengers door key cylinder switch with all doors closed. To disarm with out unlocking, send a positive trigger to the blue/black key sense wire. The key sense wire is located at the steering column.
TachometerGREEN/ blue diagnostic connector
Notes: The diagnostic connector is in driver side rear corner of the engine compartment.
Wait to start
Brake WireGREEN/ black + brake switch
Parking Brake
Horn TriggerGREEN/ red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module:Required: YesType: TransponderPart #: 555U
Notes: N/A
1999 Mazda Millenia factory alarm -- posted image.
quedog
Posted: June 05, 2004 at 8:06 PM / IP Logged
Thank You but I have this info the problem is that when I connect to the lt GREEN/ red wire the factory alarm still goes off and several other problem occur as explained in first post.
