Problem with relay on siren output
laz0r
Posted: June 06, 2004 at 12:48 AM / IP Logged
I have hooked up a relay on my siren output, all works fine, the alarm can be armed and disarmed except for when the alarm is going off I can't seem to disarm it. So somehow the relay is stopping me from turning the alarm off. Any ideas on whats happening, or maybe something else easy to use instead of a relay?
Cheers
draasch
Gold - Posts: 2,172
Posted: June 06, 2004 at 9:51 AM / IP Logged
what unit are you working with.....why did you wire up a relay????
when you say siren, are you talking about the car horn or the siren that came with the alarm...
most alarms (here in the states) have a wire that you hook up right to the siren wire. no relay needed.
if the transmitter will not disarm when the alarm is in full alarm mode, it doesnt sound like the relay is the problem.....
how do you have the relay wired up and to what wires??
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
laz0r
Posted: June 06, 2004 at 6:18 PM / IP Logged
Its a Mongoose alarm.
I'm hooking up a relay cause i've bought a wireless doorbell to act as a pager. I needed the relay to activate the transmitter when the alarm goes off.
I have pins 87 and 30 hooked to the switch of the transmitter,  pin 86 to ground and pin 85 hooked to the positive siren output.
CutDog504
Silver - Posts: 643
Posted: June 07, 2004 at 1:09 AM / IP Logged
Most likely you are getting too much rf interference from that pager thing you hooked up. I've done add on pagers many times and they all have these symptoms, VERY hard to disarm the alarm once that pager gets triggered. Most of them, you have to wait at least 8 to 10 seconds before you can disarm it, sometimes longer.
laz0r
Posted: June 08, 2004 at 2:39 AM / IP Logged
That makes sense now, any ideas on how i can make it so the transmitter only goes on for a short amount of time, so the alarm can then be disarmed? Easily that is.
Teamrf
Gold - Posts: 1,031
Posted: June 08, 2004 at 10:34 PM / IP Logged
You really don't need relays unless you're doing multiple sirens.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Teken
Gold - Posts: 1,492
Posted: June 09, 2004 at 5:10 PM / IP Logged
The maximum transmitting duration / time is limited to 60 seconds by the FCC. You would have to know exactly which component(s) configuration to alter the transmitting time.
In the old days the time was done via a drained capacitor, today the timing is done by a 555 timer.
For the 555 timer you would need to know what component / hi-low would do the *reset* on pin four of the 555 timer.
Regards
EVIL Teken . . .
