2004 Dodge Ram Valet 563t
dfrates
Posted: June 08, 2004 at 1:15 PM / IP Logged
Having a problem getting A/C, heater to work with the above system. I've tried just about every wiring diagram available, with no results. I've tried running 2 30 amp relays, which worked but got very, very hot. The system works fine except no A/C and heat. My co-worker (vehicle owner) is getting impatient as the hot wether is arriving. As he told me when he got the system as a gift, " this is a easy job". I've installed quite a few of these type of remote starts with little or no problems. Any help will be greatley appreciated. Thanks in advance.
dfrates
profuse007
Gold - Posts: 2,015
Posted: June 08, 2004 at 5:48 PM / IP Logged
heres the link for the diagram, scroll down until you see 04 ram.
carefully look at the ignition(s) or acc(s) that need to be powered. as for the relay, being hot..... never heard of it.
Houston,TX
extreme1
Silver - Posts: 1,070
Posted: June 08, 2004 at 10:35 PM / IP Logged
need 2 ign and 2 accesories
ign are pink/green and pink/white
acc are blue(12awg) and pink / YELLOW (same size as ign wire)
starter is yellow.
use the two large red wires for power.
finished 04 ram #50 or so today.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Monday, November 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
