Finally started my enclosures
AirNavy
Member - Posts: 20
Posted: June 14, 2004 at 11:35 AM / IP Logged
After messing around with a few smaller projects to figure out what I'm doing, I'm finally starting my enclosures. I'm building 3 seperate enclosures, each of which will have an Infinity Perfect 12. Anyway, enough blah, blah, blah... On with some pics....
Taped up for the corner floor molds:
Finally started my enclosures - Last Post -- posted image.
More tape... The things sticking up are pieces of airline covering bolts and bolt holes so they can be used once I'm done to secure some of it.
First layer of resin and mat. This was followed by two more layers before I popped the mold out.
One of the molds popped and ready for a couple more layers. The little brown circles are pieces of 1/4" MDF for the bolts to go through. These have since been buried in another layer except for the centers and will be built up a little more once I join the 'glass pieces and MDF pieces.
Mounting ring all fabbed up:
All three mounting rings.
Finally, the back of the mounting rings with tee nuts set and ready to go.
pureRF
Silver - Posts: 619
Posted: June 14, 2004 at 3:34 PM / IP Logged
looks good keep us posted
dream it, build it, fiberglass it
AirNavy
Member - Posts: 20
Posted: June 14, 2004 at 5:50 PM / IP Logged
Thanks to the Mod/Admin who put all of those into one post. This forum is formatted differently than the others I am used to using...
ChrisZ3
Member - Posts: 35
Posted: June 15, 2004 at 5:30 AM / IP Logged
Looks good. good idea to integrate the mdf roundels for strenght. In which car/truck are you doing this?
sam1
Copper - Posts: 151
Posted: June 15, 2004 at 9:43 AM / IP Logged
wow, that looks good so far.  keep up the good work and pics=).
AirNavy
Member - Posts: 20
Posted: June 15, 2004 at 12:04 PM / IP Logged
Oh yeah, they are strong. The trim ring is glued and screwed to the mounting ring. It's going in my 1999 GMC Sonoma Ext Cab. I figure I've been rolling with bare MDF boxes long enough. Now it's time to stop spending all my time working on other people's crap and finally get to mine...
big_ed
Member - Posts: 10
Posted: June 15, 2004 at 10:15 PM / IP Logged
Great job so far.  I like the idea of MDF circles to give them something to mount to.   How did you make those MDF rings?? is each one two pieces??
Kick his A$$ c-bass
AirNavy
Member - Posts: 20
Posted: June 16, 2004 at 12:32 PM / IP Logged
They were made with my router and a circle jig. I finally broke down and bought a set of Jasper circle jigs so I didn't have to fab up a crappy one every time (one of the best $50 I have ever spent). All three trim/mounting rings are made of two pieces. The trim ring has a 1/8" roundover on the inner lip and a 1/2" roundover on the outer. Once I glued and screwed both pieces together, I marked the holes for the tee nuts, drilled them and then put the sub back in and used it to tighten the screws down to set the tee nuts into the MDF.
Mickey
AE1(AW) U.S. Navy
Tuesday, April 30, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
