how to hook up my stereo equipment?
raptor333
Member - Posts: 46
Posted: June 15, 2004 at 2:15 PM / IP Logged
Hi I'm new at all this car stereo stuff, but I think i have most of the simple stuff. What I would like to know is how to hook up all of my equipment. What i have is 3 digital capacitors at 1 farad each, 2 1000watt  sony xplod amps, 2 12inch sony subs, a distribution block and a whole bunch of wire. can any one help?
thepencil
Gold - Posts: 1,526
Posted: June 15, 2004 at 3:11 PM / IP Logged
You can start with this. HOW TO INSTALL 1?
HOW TO INSTALL 2?
If you are unsure of something, ask. There are a lot of very skill people here who can help you out.
Be careful whose advice you buy, but be patient with those who supply it.how to hook up my stereo equipment? -- posted image.
raptor333
Member - Posts: 46
Posted: June 15, 2004 at 3:51 PM / IP Logged
Ok I should be more specific. i have 1 1000 watt amp hooked up along with my 3 digi caps. I have 2 subs running off of that amp, but i am going to add another 1000watt amp soon where should i place the digi caps and distribution block at in my wiring?
Ravendarat
Platinum - Posts: 2,806
Posted: June 15, 2004 at 4:58 PM / IP Logged
Place the disto block inbetween the caps and the amps, or between the caps and the battery, Power is non directional so It shouldnt really matter. Mabye I am wrong but Logic dictates that it doesnt matter much.
raptor333
Member - Posts: 46
Posted: June 15, 2004 at 5:43 PM / IP Logged
Thanks a lot! My other question is my amp seems to run with the power caps fine, but do I need the other wire that runs from the battery to the amp that has a fuse on it. This is the wire that would normally be used if you did not use power caps?
stevdart
Platinum - Posts: 5,816
Posted: June 15, 2004 at 6:27 PM / IP Logged
...see number 5 of the first link given to you above.
