91 ranger
greghop
Posted: September 06, 2002 at 10:31 PM / IP Logged
i need a wiring diagram for a 91 ranger for alarm instalation
what up
Platinum - Posts: 12,488
Posted: September 06, 2002 at 10:35 PM / IP Logged
|              12V|yellow              |+  |ignition harness            |
|          STARTER|pink                |+  |ignition harness            |
|         IGNITION|RED / lt. green       |+  |ignition harness            |
|        ACCESSORY|gray / YELLOW         |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |5wi|driver's kick panel         |
|     POWER UNLOCK|pink/green          |5wi|driver's kick panel         |
| PARKING LIGHTS +|brown               |   |at switch or fuse box       |
|       HEADLIGHTS|RED / yellow          |+  |at light switch             |
|     DOOR TRIGGER|BLACK/ lt. blue      |+  |under dash light            |
|       TACHOMETER|*1                  |   |ignition coil               |
|       BRAKE WIRE|lt. green           |+  |at brake pedal switch       |
|     HORN TRIGGER|yellow/lt. green    |-  |steering column             |
|           WIPERS|BROWN / white         |+  |steering column             |
|  LF WINDOW UP/DN|wht/blk - yellow    |A  |in drivers door             |
|  RF WINDOW UP/DN|RED / blk - yel/blk   |A  |in drivers door or dkp      |
Notes:
*1 Use any tan/stripe or yellow/stripe at the igniton coil.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
