car alarm wont reset
paulla17
Posted: June 19, 2004 at 11:26 AM / IP Logged
I havge an isuzu amigo.  I need to disconnect my alarm system because it wont reset.  Everytime i try to shut it down it by remote it just keeping beeping.  It has already run down my battery once.  How to I go about disconnecting it.  thanks
paul
draasch
Gold - Posts: 2,172
Posted: June 19, 2004 at 11:36 AM / IP Logged
what brand of alarm is it????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
paulla17
Posted: June 19, 2004 at 1:54 PM / IP Logged
Not sure
paul
paulla17
Posted: June 19, 2004 at 1:56 PM / IP Logged
If I get the brand can you tell me how to disconnect it ?  This thing is makin me nuts!!
paul
draasch
Gold - Posts: 2,172
Posted: June 19, 2004 at 1:58 PM / IP Logged
i will try....look up under the dash if its an aftermarket one, you will see a blck box with wires going to it...it may just be wire tied up there.....you should know it when you see it......
Good Luck
David
Ace Security
813-376-9778
Tampa
paulla17
Posted: June 20, 2004 at 7:15 AM / IP Logged
david, what do i do when i find the wire? Pull it out ?
paul
paulla17
Posted: June 20, 2004 at 7:24 AM / IP Logged
the wires from the horn tie in to a fuse and its linked to the starter and the ignition switch. tTHERES A RESET AND ANOTHER TOGGLE SWITCH UNDER THE DASH TO THE RIGHT OF THE STEERING COLUMN BUT THOSE SWITCHES WONT RESET THE ALARM NOR WILL THE REMOTE WHICH I REPLACED THE BATTERY IN
paul
