tweeters?
raptor333
Member - Posts: 46
Posted: June 19, 2004 at 12:25 PM / IP Logged
Hi, I was wondering if anybody could help me decide which tweeters I should buy. I see some with huge crossovers wired next to them would those be ok, or should I go with just tweeters with no crossover?
thapimpfromchi
Silver - Posts: 616
Posted: June 19, 2004 at 12:43 PM / IP Logged
Depends all on you. Depends on how picky you are about your music. If you are just looking for some more treble then you could get a set of tweeters for like 10-15 bucks and be set, but if you are going for all out SQ, then you are going to want to get those crossovers. Not only for the tweeters, but for everything else in your system.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
DYohn
Platinum - Posts: 10,741
Posted: June 19, 2004 at 12:57 PM / IP Logged
ALL tweeters need a crossover or you will blow them.  Period.  You either need to cross them over with a passive system (probably like you see connected to the tweeter) or by running them off dedicated amplifier channels with a high-pass set for the tweeters (generally around 3500Hz) on or before the amp.
raptor333
Member - Posts: 46
Posted: June 19, 2004 at 1:05 PM / IP Logged
thanks
