Blaupunkt headdeck overheating
Hobnib
Posted: June 21, 2004 at 4:03 AM / IP Logged
okies..... I recently brought my girlfreind a Blaupunkt head deck. Just a cheapy one for her sh*tbox. Anyways i have installed it but whenever the car is turned on and power is reachign it. it turns of within a few seconds as it is overheating.
I have tried running another constant power cource from the batery but it still does it.
What could the problem be?
-Hobnib
DYohn
Platinum - Posts: 10,741
Posted: June 21, 2004 at 9:36 AM / IP Logged
What's the impedence of the speakers you have it connected to?
kgerry
Platinum - Posts: 3,455
Posted: June 21, 2004 at 9:50 AM / IP Logged
check for a pinch or short on the speaker wires.... or check to make sure you have the wires connected properly.....i'd bet a hundred bucks that your problem is a wiring problem...
KIM most Blau units ( all actually ) utilize a floating ground output...which means ALL the speaker wires have to be isolated from each other and also from the chassis of the vehicle....grab a DMM and meter all your speakers for continuity to ground... i suspect you'll find the problem......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
