digital multimeter/solder
kel789
Copper - Posts: 128
Posted: June 21, 2004 at 8:10 PM / IP Logged
There are many levels of digital multimeter. What type of digital multimeter and what size of solder should I purchase? Thanks.
Javelin3o4
Copper - Posts: 239
Posted: June 21, 2004 at 9:33 PM / IP Logged
I have the snapon/bluepoint MT586BK multimeter does pretty much everything including reading RPM's.
http://buy1.snapon.com/catalog/pro_det.asp?P65=&tool=diagnostics&item_ID=16688&group_ID=1367&store=snapon-store&dir=catalog
kel789
Copper - Posts: 128
Posted: June 21, 2004 at 9:52 PM / IP Logged
it costs more than the security system. i thought i can get one for less than $50.
auex
Platinum - Posts: 5,041
Posted: June 21, 2004 at 10:49 PM / IP Logged
Home depot usually has cheap generic DMM for 20 bucks. Just use electronics grade lead solder.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
kel789
Copper - Posts: 128
Posted: June 21, 2004 at 10:57 PM / IP Logged
thanks.
Javelin3o4
Copper - Posts: 239
Posted: June 22, 2004 at 3:52 AM / IP Logged
you can pickup cheapies from sears i think they have one for like 20 bucks. I havce the snap on one cause im an installer so i use it almost every day.
kel789
Copper - Posts: 128
Posted: June 22, 2004 at 10:21 AM / IP Logged
do you use a regular solder iron? i bought one a year ago. it's pretty big. is it a concern?
draasch
Gold - Posts: 2,172
Posted: June 22, 2004 at 11:59 AM / IP Logged
your soldering iron needs to low wattage. if it too hot, it will burn the solder or damage the wire.....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
kel789
Copper - Posts: 128
Posted: June 22, 2004 at 3:04 PM / IP Logged
what wattage should it be?
flynntech
Copper - Posts: 275
Posted: June 22, 2004 at 10:46 PM / IP Logged
15 watt weller soldering iron or cordless butane torch/soldering tip
.031" dia rosin core solder
You have to be horrible with a soldering iron to burn stuff, I could solder with a 150 watt soldering gun if I had to.
I have $30 crafstmen multimeter and it's as accurate as a $400 Fluke, it won't read RPMs, but everything else it does just fine. It will read DC duty cycles, so that might work for RPMs, I've never tried it.
