1995 Ford Explorer, Autopage RF-305
Andrews2186
Member - Posts: 7
Posted: June 23, 2004 at 12:37 PM / IP Logged
Does anyone have the alarm diagram for a 1995 ford explorer ???
Jkcan
Member - Posts: 9
Posted: July 04, 2004 at 1:58 PM / IP Logged
+12v   yellow.... Ignition   GREEN/ purple....starter   RED / lt blue....lock    pink / YELLOW......unlock   pink/green  (lock and unlock are a - trigger in the driver's kick panel....parking lights    PURPLE / white in driver's kick....door trigger   BLACK/ lt blue.   let me know if ya need more info.
10 years and counting....
Andrews2186
Member - Posts: 7
Posted: July 07, 2004 at 2:05 PM / IP Logged
How Do I Disarm The Factory Alarm?? I Was Told That I Would Have To Connect Two Wires Together.....Something About The Arming, And The Disarming?? I Don't Know, Can Someone Help Me??
Jkcan
Member - Posts: 9
Posted: July 09, 2004 at 4:09 PM / IP Logged
the factory alarm will only arm if you lock the doors(arm the alarm) with the door open....if you get out, close all the doors, then arm the alarm, then the factory alarm is not armed.  I have a note here about a dark GREEN/ purple wire in the driver's kick panel, but not sure if it is arm or disarm...check it out.  good luck
Andrews2186
Member - Posts: 7
Posted: July 25, 2004 at 10:56 AM / IP Logged
Does Anyone Have The Factory Alarm Diagram?
Andrews2186
Member - Posts: 7
Posted: July 25, 2004 at 11:03 AM / IP Logged
I just installed this alarm into my 1995 Ford Explorer and for some reason the LED will not light up and im not sure if it is working or not is there a certain way I can test it?
Tuesday, April 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
