1987 toyota corolla wires
smoothdog
Posted: June 28, 2004 at 5:29 PM / IP Logged
does any one know what the wires colours are for what part of a 1987 toyota corolla
what up doc
swamprat323
Gold - Posts: 1,335
Posted: June 28, 2004 at 6:57 PM / IP Logged
Make:
Model:
Year:
Toyota
Corolla
1985-87
Alarm
Function Color Location
Constant 12 volts BLACK/ RED OR WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ ORANGE IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) PASSENGER PIN SWITCH
Trunk Pin Switch BLACK (-) ANTI-THEFT MODULE BEHIND DRIVER DASH
Parking Lamp GREEN (+) AT FUSE BOX
Power Lock BLUE/WHITE DRIVER KICK #201
Power Unlock BLUE/RED PANEL
#201- See Negative Pulse Door Lock Diagram.
Accessories
Window Up D\ GRN/BLK P\ GRN @ MAIN
Window Down R/ RED / BLK S/ RED / BLU SWITCH #211
Ign Key Warn BLUE/BLACK (-) STEERING COLUMN HARNESS
Trunk Release N/A
OEM Horn GREEN/ RED (-) STEERING COLUMN HARNESS OR AT RELAY
Headlights RED / WHITE (-) AT HEADLIGHT SWITCH
OEM Alarm Arm N/A
OEM Alarm Disarm N/A
#211- See Reversal Rest At Ground Power Window Circuit Diagram.
Remote Start
Tach Signal BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory BLUE/RED IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN / WHITE (+) SWITCH ON BRACKET ABOVE BRAKE PEDAL
Reverse Light RED / BLACK (+) AT SWITCH ON TRANSAXLE
Rear Window Defrost
* Some Models Carburated.
InterConnect Harness
Function Part # Available Location
StrInt,+12,Gnd,Ign no
Horn Honk no
Lock & Unlock no
Light Flash no
Dome Light no
Trunk Switch no
AL-100 / VIP-4000 no
Remote Start no
Thursday, October 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
