Is it too much
harvey1959
Copper - Posts: 94
Posted: June 30, 2004 at 6:00 AM / IP Logged
I have a set of Panasonic CJ-DD133 5 1/4 speakers in the front doors of a 94 Dodge Spirit.  They are running of of HU power. They are rated at amp power range of 2 to 35 watts.  If I use my Lightning Audio F and F amp rated at 50@2 at 4ohms will this be too much power for the speakers?
Harv
stevdart
Platinum - Posts: 5,816
Posted: June 30, 2004 at 6:23 AM / IP Logged
You can always try it and replace the speakers if they break up at higher volumes.  You would want something that will handle at least 35-50 watts anyway if you like some loud volume now and then.  But you shouldn't worry that you'll ruin them instantaniously, because you would hear the distortion and would turn them down.
haemphyst
Platinum - Posts: 5,059
Posted: June 30, 2004 at 8:46 AM / IP Logged
is that 50 watts per channel and two channels, or 50 watts per channelsat 2 ohms? It'll make a difference. If the 50 X 2 spec is the one we are interesed in, then you will just have to be very careful with the gain control, making sure it is set absolutely correctly. If the spec you have is 50 X 2 @ 2 ohms, then you should be OK, as your amp should only make 25 to 30 watts into them (but still be careful with the gain). I am only giving you both scenarios, as I am not absolutely certain of what you were saying in your original question. Whatever happens, make certain your gain control is set correctly, and it does not matter how much power tham CAN make.
kfr01
Gold - Posts: 2,121
Posted: June 30, 2004 at 10:36 AM / IP Logged
Hi, I feel like I give this advice a lot, but here it goes, just call me mr. crossover.
If you're going to start pushing your 5-1/4" speakers with an amplifier remember to cross them over above 100hz.  Shoot, even if you decide to continue to power them with your head unit, I'd order some bass blockers from sounddomain or crutchfield.
New Project: 2003 Pathfinder
harvey1959
Copper - Posts: 94
Posted: July 03, 2004 at 7:12 PM / IP Logged
Stevdart,   I don't want to ruin the speakers.  That was the best $12.00 I ever spent in my life.  They were on clearance at Circuit City and it seems like a lot of places are getting rid of 5.25 speakers.  I'm running HU power right now and these speakers sound great.  I figure amplified would be even better.  The tweeters are rated at 50 KHZ.  I have treble set to -2 on my HU and they still sound clear.  Thanks for the advice guys. Cross over above 100hz sounds good Bass blockers also.
Harv
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
