2001 Chrysler Voyager
blcox4
Posted: July 01, 2004 at 11:55 AM / IP Logged
Iam installing a Rattler 100 keyless entry system. Does any one have a wire digram for the door lock system and what type of system this van may have.
Thanks very much
draasch
Gold - Posts: 2,172
Posted: July 01, 2004 at 12:06 PM / IP Logged
Power Lock VIOLET/D GREEN AT B.C.M.LOWER LEFT OF STEERING ***
Power Unlock SINGLE WIRE SYSTEM COLUMN IN PIN 21 WHT 34 PIN CONN.#217
*** Chassis Ground Thru A 5.3k To Lock And Chassis Ground Thru A 2k Ohm Resistor To Unlock. ( Connector Is Third Up From Bottom Of BCM) #217- See Single Wire Resistor Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
blcox4
Posted: July 02, 2004 at 10:44 AM / IP Logged
ok I understand the setup for using the reistors but do I need to use realys with them and I have looked on this site it states for the Dodge caravan the wire I need to use is a white w/green or is it the purple and green wire.
Thanks,
