3 amp question
raptor333
Member - Posts: 46
Posted: July 02, 2004 at 1:39 AM / IP Logged
If I want to do a 3amp connection can I use one ground and connect one ground to the other amps ground to the other amps ground?
stevdart
Platinum - Posts: 5,816
Posted: July 02, 2004 at 6:27 AM / IP Logged
You can do that through a distribution block, same as you would use a distro for the power wire inputs.  The ground wiring must be as large as or larger than the power wire for each amp.  Don't run the ground from one amp to the ground terminal of a second amp.  I prefer to run separate grounds from each amp, and connect at the same chassis grounding point, or at least within an inch or two from each other.  But if you use a distro for ground, you could use a simple unfused block like this one for the grounds.
For example, if you have a main power wire from the battery at 4 gauge, then split out with 8 ga. to each amp through a distro, then do the same in reverse for grounding, ending up with a 4 ga. wire to the car chassis metal.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
