94 nissan altima
alvis ferrell
Posted: March 13, 2002 at 8:05 AM / IP Logged
I NEED TO KNOW HOW TO REMOVE THE OLD STEREO TO PUT IN A CD PLAYER
a1 electronics
wirewise
Moderator - Posts: 489
Posted: March 14, 2002 at 10:17 AM / IP Logged
The unit mounts from the front so you'll have to remove the bezel surrounding the head unit. Pretty sure you only have two screws located at the bottom of it and the rest of it snaps in. I could be wrong, but as you're removing it, you'll know if there are more, just go easy on it to be safe. After you pull off the bezel, the screws holding in the unit will be easily accessible.
~~wirewise~~
alvis ferrell
Posted: March 15, 2002 at 8:26 AM / IP Logged
thanks the bezel also has a screw under the left side hidden & four screws
under the panel around the t-shift thanks for the help the wire diragram
was very helpful thanks 12volt .com...........
a1 electronics
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
