2004 Honda Civic Wiring
jaketone
Posted: July 03, 2004 at 5:27 PM / IP Logged
I have a brand new 200, 4 door honda civic. i have been unable to get behind
the center/radio console to look at the
exact wiring which goes directly into the radio. Anyways, can you help me with some sort of diagram or anything?
jaketone
Posted: July 03, 2004 at 5:28 PM / IP Logged
I have ran all the wiring for the amp/sub except the remote wire.  I am unsure which wire is the remote wire at this point.
raydawg357
Silver - Posts: 769
Posted: July 06, 2004 at 8:58 AM / IP Logged
To remove your stereo is simple.  Remove the rubber boot from around the shifter, now gently pry the outer trim around the shifter outwards,  there will be two screws to the front of the shifter that have to be removed.  Now pull the lower bezel towards you revealing the two 8mm screws that hold the factory radio in place.  The harness for this vehicle is the same as the 98 and newer hondas.  Good Luck.
Do it right the first time
