viper 550 esp install question
Patrick27
Posted: July 05, 2004 at 12:50 PM / IP Logged
I had a viper 550 esp remote starter alarm intalled "profesionally" now I am having problims with it the car wont start normally it acts like the battery is dead just clicks if I cycle the ignition a few times eventully it will start.  but when it dont start I pull the key out of the ignition the car will try to start itself just has a loud clicking untill I press the brake that is the only way to stop it. the strange thing to me is that after I get the car started it works fine if I restart it right away if it sits a few hours I have the same problims I already put a new battery in it.  I looked at the splices cheap crimp and t-taps I know that I could have a Number of problims so if no one has a answer can some one get me the wiring digaram for the alarm system I will uninstall the whole thing and re install it or just leave it out the car is a 2001 pont grand prix
Thank you if any one can help
swamprat323
Gold - Posts: 1,335
Posted: July 05, 2004 at 5:15 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red & RED / white     |+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|pink               |+ |ignition harness            |
| SECOND IGNITION|white               |+ |ignition harness            |
|        ACCESSORY|orange              |+ |ignition harness            |
|       POWER LOCK|lt. blue            |- |driver kick panel           |
|     POWER UNLOCK|white               |- |driver kick panel           |
|       LOCK MOTOR|gray               |   |driver kick panel           |
|     UNLOCK MOTOR|tan                 |   |driver kick panel           |
|    DISARM DEFEAT|tan                 |   |passenger kick panel        |
| PARKING LIGHTS +|brown               |   |at switch                   |
|       HEADLIGHTS|yellow              |+ |at switch                   |
|     DOOR TRIGGER|tan and dark blue   |- |*1                          |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|RED / black           |- |under rear deck             |
|TRNK/HTCH RELEASE|BLACK/ white        |+ |at switch                   |
|FCTRY ALRM DISARM|ORANGE / black        |- |driver kick panel           |
|       TACHOMETER|white               |   |pin 8, conn. 2 @ PCM *3     |
|      SPEED SENSE|dk.green            |4 |*2                          |
|       BRAKE WIRE|white               |+ |stop light switch           |
|     HORN TRIGGER|black               |- |steering column             |
|           WIPERS|gray               |+ |steering column             |
| LF WINDOW UP/DN|dk. blue - brown    |A |LF window motor in door     |
| RF WINDOW UP/DN|lt. blue - tan      |A |drivers kick panel          |
| LR WINDOW UP/DN|dk. green - purple |A |drivers kick panel          |
| RR WINDOW UP/DN|lt. green - purple |A |drivers kick panel          |
Notes:
NOTE: This vehicle is equipped with the pass-key III immobilizer. Use DEI part number 555G or 555U to bypass during remote start mode. *1 The tan is located in the drivers kick and catches only the drivers door. The dark/blue is located in the passenger kick panel and catches all other doors, must diode isolate these wires.   *2 Located at a 10 pin plug on the front of the drivers strut tower. There are two dk.green wires there, use the one in the corner of the plug. *3 The PCM (Powertrain Control Module) is in the air cleaner assembly.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
