2000 Alero
beebs
Posted: July 06, 2004 at 3:32 PM / IP Logged
I am looking for some information on a 2000 Alero.  I am installing a keyless entry/remote start module.  I have a wiring chart, but I haven't been able to find a description on one wire.  I am looking for the Park/Neutral switch wire that is connected to the bypass switch on a DEI Valet module.  I am assuming it is in the console by the gearshift.  I checked one suspected wire, but it wasn't correct.  All the other wiring goes to lights in the console.   Any info on color and location would be appreciated.
beebs
kgerry
Platinum - Posts: 3,455
Posted: July 06, 2004 at 3:44 PM / IP Logged
this wire gets grounded through the supplied switch
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
sroth140
Silver - Posts: 513
Posted: July 07, 2004 at 12:43 PM / IP Logged
cars that new you dont have to worry about finding that wire.  it makes sure the car is in park or neutral when remote starting... but try it your self.  put the car in drive and try to crank it, the starter wont turn at all.  so, use the toggle switch and place it in series to the P/N wire and ground it.
MECP certified installer
